Go to Post When a vomit shooter runs out of balls, is it dry heaving? :p - Lil' Lavery [more]
Unread 23-05-2008, 02:00
Nameless Nameless is offline
FRC #0074
Nameless is an unknown quantity at this point
2008 Gyro
The pins on the 2008 gyro are labeled as follows:
Code:
G 5 R   G 5 T
B R W   B R W
What do R and T refer to? T appears to be angular velocity, from its values.
/David
To anyone struggling with the gyro, here's what I know:
The second row (B, R, W) refers to the colors of wire (black, red, and white). The G and 5 refer to GND and +5V, respectively.
Unread 23-05-2008, 07:09
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: 2008 Gyro
T is for Twist
R is for Relative Temperature
200 Sensor Manual: http://usfirst.org/uploadedFiles/Com...sor_Manual.pdf
Unread 23-05-2008, 09:10
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: 2008 Gyro
Really, T is for Temperature, and R is for angular Rate. However, they screwed up the silk screening, so they are flipped.
Unread 23-05-2008, 11:07
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: 2008 Gyro
For those that had good results from the gyro this year, did you use the code in for the temperature calibration?
We used WPILib this year, but did not attempt to incorporate the temperature calibration, and it worked okay, but could have been better
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 23-05-2008, 12:26
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
Re: 2008 Gyro
What kind of applications do FIRST teams use temperature for generally?
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 23-05-2008, 12:30
Engineering Mentor
Re: 2008 Gyro
According to the 2008 sensor manual, the gyro measurements vary with temperature as such:
The “R” output varies by 8.4 millivolts per degree Kelvin. A temperature of 298 K (about
25 Celsius) will give an analog output of 2.5 volts. Higher temperatures will provide
higher voltages. Cooler temperatures will provide lower voltages.
So, you would probably use it if your gyro is mounted in a location where the temperature might be changing a lot. We didn't use it this year, and just sort of assumed that termperature was a constant. It probably would have been a little accurate if we had used it though.
Unread 23-05-2008, 18:09
FRC #0074
Re: 2008 Gyro
Thanks for all the help and especially the link to the sensors manual.
/David
2008 Offseason event MARC being moved to JUNE 28, 2008 Steve Ketron Off-Season Events 10 21-03-2008 07:55
Bad 2008 KOP Gyro - Need Replacement taberski Programming 2 17-02-2008 05:37
2008 Gyro Code FireJet Programming 13 14-02-2008 17:06
2008 Pre-Ship 2008 Suffield Shakedown Scrimmage Webcast stevek General Forum 0 13-02-2008 23:55
gyro odin892 Programming 0 08-04-2003 09:59
