Go to Post I've never liked the pressure pads. This just confirms my suspicions: Pressure pads hate robots. It must be some inferiority complex or something. - Andy A. [more]
Unread 24-05-2008, 11:45
chiclops chiclops is offline
chiclops is an unknown quantity at this point
Question Programming PIC using CDC?
Hello!
I wanna know how can I write my program to a PIC microcontroller without using MPLAB.
Thanks in advance!
Unread 24-05-2008, 13:10
programMORT11
Posts: n/a
Re: Programming PIC using CDC?
Do you mean that you want a different IDE or a compiler? Microchip's mcc18 compiler is really the only compiler that works for the PIC. Howeverm if you're looking ata different IDE, there are a lot of options, such as DevC++ and CodeBlocks. Our team uses CodeBlocks, since we find its plugabble architecture nice for any extra functionality we want to add, and its pretty easy to add a new compiler. You just add new compiler and add the linkers and libraries and compile flags, which you can get from a build log in MPLAB.
Unread 24-05-2008, 13:21
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Rookie Year: 2007
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
I am fairly certain that you have to compile in MPLAB, its all proprietary to microchip. My team codes in eMacs and then builds in MPLAB
Unread 24-05-2008, 16:35
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
Team Role: Leadership
Rookie Year: 2007
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Actually, there are several different compilers that support PIC18 targets, aside from just Microchip's (do a quick Google search).
Now, whether or not they support the Microchip C18-specific extensions used in the IFI code is another story.
Unread 24-05-2008, 16:37
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I'm not exactly sure this is a FIRST application here. Outside the FIRST box might work here, too.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 24-05-2008, 17:05
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
our programmer is always programing pics for various projects and he doesnt use mplab
If it isn't broken, Fix it till it is ~ Baker
Unread 24-05-2008, 18:15
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
As long as you have the compiler tools, you can build your own tool chain, and you won't have to use MPLAB.
Unread 24-05-2008, 19:43
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
for non-FIRST microcontrollers, i use a microchip PICSTART PLUS programmer and CCS-C compiler. it has its own IDE, but i prefer to use it with MPLAB.
www.sparkfun.com has a lot of PIC resources
Unread 25-05-2008, 13:37
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Well, you could always look up the opcodes for each machine language instruction, and the microchip .hex file format and write your code in a text editor... but I'm guessing that you probably don't want to get quite that "bare bones".
Alternatively, you can presumably write your C code in any text editor and then compile it using PICC Lite (a freeware compiler, available from Microchip) and then compile it using command line options.
These are both kind of silly options since MPLAB makes doing both of these tasks much easier... maybe you want to avoid C or assembly language all together... in which case I would recommend PIC BASIC Pro or PIC BASIC (I much prefer the pro, even though it is more expensive) from www.melabs.com
They also have their own IDE... MicroCode Studio, I believe it is called.
Jason
P.S. If you can possibly run MPLAB, I recommend learning to use it... some of the emulator and debugging functions are quite useful.
pic: Programming team IndySam Extra Discussion 2 24-03-2006 12:40
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC Programming John Gutmann Electrical 3 30-08-2005 11:51
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
TI programming using Z80 assembly language Jeff Wong Chit-Chat 1 07-06-2001 01:27
