pic: VEX Mecanum Project:Done(ish)
Re: pic: VEX Mecanum Project:Done(ish)
They look good, they remind me of my mecanums from a few years ago, except well, better. How's your speed with those because when I had mine they would strafe super slow? Also is there any kind of lubricant or anything between the rollers and the hub?
Here mine if you wanna check them out. http://www.chiefdelphi.com/media/photos/28631 |
Currently strafing is a bit slow, but tomorrow heat shrink will be added to the rollers for traction and graphite lubricant to reduce friction.
The plan for the next iteration is to use 1/4" shaft and bearings to have a very smooth roll. |
Never thought of heat shrinking the rollers... might have to try that
I might have to try to make me some after I finish my vex tank with CMU cam.
Wow Chuck, thats absolutely amazing!
you need to tell me when your presentation is, I need to see that thing. |
Very nice design, Chuck. Good job getting this done.
Sincerely, Andy Baker |
Here's a short video of Chuck & Ron's Vex Mecanum robot.
http://video.google.com/videoplay?do...38259993&hl=en This is a great example of how the FIRST community inspires and supports an idea. For three years both of these students were exposed to 357's Jester Drive and the process for molding/manufacturing wheels and hubs. That initial spark and solid relationships turned into a project idea, and, with support from 357, Andrew, and others the project turned into reality. While this is not the first or last Vex Mecanum drive we will ever see, it certainly was a fabulous learning experience for the students involved that brought together a well developed "at home" process (357's roller/hub design), the use of our 3D printer, and the award winning Vex platform. All that and a great application of our school's required senior project. Chuck will be studying Mechanical Engineering at Drexel in the fall and Ron will be attending Case Western for Mechanical & Aeronautical Engineering. Now they both need to do well because everyone knows. No pressure, guys Last edited by Rich Kressly : 28-05-2008 at 07:29. |
so.... Where are you selling these babies?
![]() -Vivek |
#10
VERY impressive work gentlemen. I guess I'd better watch my back if I want to keep my job!
Kudos on an excellent design. It is especially cool that you actually took the time to get these built. Anyone can draw something in CAD, but it takes some real work to get a design fully functional. (It also shows real character to continue to improve a "completed" design.) I imagine you learned quite a bit from this process. -John |
| pic: vex mecanum 1 | psyco_klown | Extra Discussion | 9 | 05-05-2008 23:22 |
| pic: 172 almost done-ish! | K.Porter | Robot Showcase | 4 | 19-02-2008 16:58 |
| 2200 - Done (ish) | Bochek | Robot Showcase | 5 | 16-02-2008 21:52 |
| pic: Mecanum Wheel Project - Rev. D | Madison | Technical Discussion | 17 | 07-08-2006 18:19 |
| pic: Mecanum Wheel Project - Rev. E | Madison | Technical Discussion | 8 | 13-07-2006 13:31 |
