Go to Post No one can deny the awesome power of FIRST. - Queen_of_Mascot [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 30-05-2008, 01:50
R.C.'s Avatar
Happy Birthday! R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Help With Solidworks: Diagonal
How can i make diagonals like the pink team made on their frame using Solidworks. Or how to extrude a scissor or diamond pattern
Thanks,
cd
http://www.chiefdelphi.com/media/img...a009e38b_l.jpg
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 30-05-2008, 06:40
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Help With Solidworks: Diagonal
One way to skin this cat would be to extrude the basic shape (4x4" box), and then cut the desired shapes into the side with the extruded-cut tool. You can pattern these shapes to save a little time.
Unread 30-05-2008, 07:39
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Thanks,
cd
In Sheet Metal, there is a tool called VENT.
1. Create a flat rectangular Base Flange (this is an Extrude feature but in Sheet Metal).
2. Create a sketch that is rectangular. This is the boundary of your diagonals. In the same sketch, draw the criss-cross lines. You can use the Sketch Pattern feature so the lines are equidistant apart
3.Exit the Sketch
4. Select VENT from the Sheet Metal toolbar. First select the outside boundary. Then select the criss-cross lines for Ribs.
This can also be used not just for a cool design but also to indicate the percent of open space for air flow.
Other patterns can be used with this technique. Click on the ? in the Vent Property manager to see different styles in creating decorative and functional vents. As long as the material remains at constant thickness you can use Sheet Metal. Otherwise, use Rib. Marie
FirstCadLibrary partners with SolidWorks Ed Sparks CAD 2 15-04-2008 12:12
pic: Marie on OCC Chopper Designed with SolidWorks mplanchard Extra Discussion 4 10-04-2008 17:59
HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! drewjones13 Programming 1 17-01-2008 20:52
Hurdling the Ball in a Diagonal Way... JspRaven General Forum 2 10-01-2008 10:04
2WD diagonal System Tom McCurdy Technical Discussion 11 23-01-2005 01:02
