Go to Post Its just going to be a dirt game. We are going to be using shovel bots to dig for gold. Anyone who strikes oil gets the 100 point bonus! - Uberbots [more]
Unread 02-06-2008, 19:41
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Backlash
How much backlash is recommended for gears? I am using AM gears (20 dp, 14.5 pa) and we have the option of cutting the side plates on either an old mill or a waterjet. The mill is by no means state of the art and I would guess that the tolerance is .005". The waterjet tolerance as listed on their website says .005" but our mentor assures me that they can get at least .003" if not much better.
How much backlash would you recommend between two gears? I was thinking .002" but am not really sure if that will be enough.
Also, what are some good places to get hole reamers for .005" under 7/8" and 9/8"? I am planning on having the waterjet cut a smaller hole than needed for the bearing and then pocketing that hole with a reamer so I can press fit an unflanged bearing in there.
thanks, Vivek
EDIT: err... It seems that reamers are meant to go all the way through the hole. What is the best way to make a hole like that? I am planning on using .25" aluminum and leaving a lip of .13-.15" for the bearing to sit against. Gimme a break, I'm still a n00b.
"we don't build robots, we build people"
window motor backlash nic_radford Motors 15 14-02-2004 19:06
