Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 04-06-2008, 12:34
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Re: Backlash
Originally Posted by Ken Patton View Post
We have typically used a 0.08 mm increase in gear center distance with our custom-made geartrains. My guess is that this is on the high side compared to some others who make their own boxes, but these are typically wire-edm'd gears whose surface finish is a little rough before run-in. Our gears are not very wide either.
We run them in at no load (i.e., not driving the chassis around, but just running the wheel while it is off the ground) for an hour or so. We have been using the same tube of Amsoil grease (apparently its "racin' grease" ) for several years now....
If I was using purchased, nicely finished, wider gears, I think something in the 0.05 mm range would be my choice for the amount that the center distance is increased.
The looser distances like I am suggesting here make the boxes easier to assemble and get low geartrain friction, in my opinion.
Ken
In my opinion, Ken is THE expert on this subject.
I recommend everyone interested in high-efficiency gearboxes takes a close look at the practices he recommends. (You'll also find any other tid-bits of advice you can get out of him to be HUGELY beneficial.)
"Ain't nothing that rings like a Huskie..."
-John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 04-06-2008, 15:45
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Backlash
Ken
So if I were to put two gears right next to each other, I would put a distance of .002" between them or .004"? .002"=~.05 mm
thanks, Vivek
"we don't build robots, we build people"
window motor backlash nic_radford Motors 15 14-02-2004 19:06
