pic: Evolution of a Gearbox: rev 7 exploded
Re: pic: Evolution of a Gearbox: rev 7 exploded
What is your plan for machining the bottom mounting piece. From what I can see it looks kinda complex.
aluminum plates welded together
Did you draw the DeWalt gearbox? or did you download it from somewhere? if so, where?
Thanks |
our CAD team had one already made, i just converted it to solidworks.
That is one pretty design.
How much does it way? |
how does your design go into the DeWalt? would you all be making/buying a shaft and a gear to fit inside? how much effort are you expecting on the DeWalt alone?
having 0 hands-on experience with the DeWalt gearbox I am somewhat clueless. |
a 3/8 keyed shaft will enter the gearbox and interface with the 2nd planetary via a plate that slides over the carrier plate pins (like this) then that shaft will exit dewalt and be supported by two bearings. the gear attaches to that shaft.
| pic: Evolution of a gearbox rev 4 | roboticWanderor | Extra Discussion | 9 | 27-05-2008 09:19 |
| Exploded view of FP gearbox? | VEN | Technical Discussion | 1 | 13-03-2008 21:35 |
