Go to Post Thankfully, my student drivers are a lot smarter than me and covered for me on several occasions. - Paul Copioli [more]
Unread 11-06-2008, 19:46
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: pic: West Coast Altered
Originally Posted by NickE View Post
To save a bit of weight, you could probably go with smaller sprockets.
Are you using 25 or 35 chain?
Also, what is the material for the gearbox sideplates?
254 typically uses Delrin, as it is much lighter than aluminum and strong enough for this application
Finally, when looking at your picture, there are grooves cut out in the front of the side tubing.
Am i correct in thinking that you will be putting another black crossbar in the front?
The sprockets are for #25 chain. The reason that they are so large is because I was originally planning on using cross braces that are as tall as the sides and the sprockets would need the chain to clear them. I simply haven't been motivated to change them.
The side plates are currently aluminum but theres no reason they need to stay that way. The grooves in the front to so that the sides are identical and can be switched without needing to have one of each. The actual would probably use another to mount bumpers.
Unread 11-06-2008, 20:03
NickE's Avatar
NickE NickE is offline
_
FRC #0254 (The Cheesy Poofs)
NickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond repute
As a compromise, you could always make the front and back crossbraces the full height of the sidebeams, and use the half size ones for the in-between crossbraces.
This would allow you to keep the sprockets small and to still retain more strength than having all half size crossbeams.
Unread 12-06-2008, 01:21
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Originally Posted by CraigHickman View Post
Nice! Looks cool!
I also like your gearbox design....
Yeah, definitely inspired by the same team(s) yours was.
Unread 12-06-2008, 01:38
CraigHickman
Posts: n/a
Actually, my design was inspired by a whiteboard sketch by James Fry. Who knows where he got his ideas, might have been there. As for the actual mechanics, mine was a single speed, akin to this one, rather than a two speed, akin to the ones you posted. Same shape though (a no-nonsense, no real extra material design that I wholeheartedly approve of).
Unread 12-06-2008, 20:53
Nica F.'s Avatar
Nica F. Nica F. is offline
Mechanical Design Engineer
AKA: That silly panda girl from back in the day.
Nica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond repute
Pretty hard to say this design posted was a alteration of your design alone though. West coast is obviously known for their drive designs and I must say that the link you posted was up way after a few greats such as 254 and team 60. Just throwing it out there.
On another note, alex, thanks for sharing your take on the west coast drive with the rest of chiefdelphi it's always nice to see what all the teams get out of other great role model teams.
Mechanical Design Engineer 
Purdue Aeronautical and Astronautical Engineer Graduate - Boiler up!
Team 22 Double Deuce & Team 4 Element Alumni
Unread 12-06-2008, 02:54
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
i have some better pictures of that drivetrain if anyone wants to take a look! man i had to dig deep to find them but i got em!
Unread 12-06-2008, 20:05
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
roboticWanderor i would like to see them or can you email them to me at rcthekid1323@gmail.com
Thanks
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 12-06-2008, 20:54
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Thanks
How about using CD-Media?
http://www.chiefdelphi.com/media/photos/25814
http://www.chiefdelphi.com/media/photos/23573 (And scroll down on this one)
http://www.chiefdelphi.com/media/photos/25071
There's a few more there too. You may have to search for both the teams involved.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-06-2008, 21:32
Spark The Ancient
righto, uploading now.
Unread 12-06-2008, 22:32
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
http://gallery.rawc.net/main.php
The gallery includes photos from regionals and off season events that either 254 or 968 attended, as well as build photos and other misc stuff.
Most of the pics are a little better than the stuff on CD Media.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 13-06-2008, 00:13
Spark The Ancient
thats where i found it, unfortunately they don't have any 2008 robot pinups yet. (cmon guys!) but there are some great pictures from previous years!
West Coast Post-Season Scrimmage rsilverstein Off-Season Events 12 27-03-2007 23:52
pic: West Coast Collaborationz and Team 254 Present phrozen solyd Robot Showcase 22 28-02-2005 01:31
anyone in california/ west coast Cappy697 Chit-Chat 19 06-02-2004 13:56
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
Types Robots of the WEst Coast SpaceOsc Rumor Mill 5 27-01-2003 23:38
