Go to Post Consider yourself mentored, you have learned a lesson: "Don't stick your hands in icky things." - Amanda Morrison [more]
Unread 12-06-2008, 13:48
buickgsxstg174 buickgsxstg174 is offline
FRC #0522
buickgsxstg174 is an unknown quantity at this point
Programming with the new interface
Im just wondering if there will be a sample code for labview and possibly windriver as there was for easy c to understand the syntax needed to write the operator control and the autonomous modes that work right and efficiently. I understand that labview will not be as easy as easy c, but that it will be more involved, in depth and tweakable. Also, will there be a labview gui written with some express vis for features like motor control and sensor use as there was with easy c, or will we need to play around over the summer to try to make those ourselves. (I'm sorry that I keep referring to easy c when I make comparisons of labview, but being that those are the only two programming guis that I have used and experimented with, I like to use it as a reference.)
Also, we are currently programming in mplab with C and while on this site, another question arose, this time about windriver. I understand that C++ is better and more advanced than regular C, but will there be a familiar experience while programming. Im not asking for a user_routines.c or a user_routines_fast.c file, but will those of us who have in the past sweared by programming in mplab than easy C be lost or hindered by our past programming experience?
Last question.
I understand that there are many new and interesting features that come with the national instruments controller, but are there many teams out there who are confident that they can use them as advertised?
Hmm, so, it uh, it wasnt supposed to do that. Now I know.
If all you want the robot to do is spastically spin around in circle, set a couple things on fire and void a few warranties, then it will work perfectly.
Unread 12-06-2008, 14:51
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Re: Programming with the new interface
Originally Posted by buickgsxstg174 View Post
I understand that C++ is better and more advanced than regular C, but will there be a familiar experience while programming [...] will those of us who have in the past sweared by programming in mplab than easy C be lost or hindered by our past programming experience?
C++ was primarily built upon C, and so virtually everything you have done in C can be done exactly the same way in C++, with a few minor exceptions which are easily learned/fixed. Those who know C already will be in a WONDERFUL position to use C++ for the new control system, and if they make full use of the object orientation of C++, they will be at a great advantage. Previous C experience will in no way hinder you or make you lost.
I cut myself shaving with Occam's razor.
Unread 13-06-2008, 07:58
Im just wondering if there will be a sample code for labview and possibly windriver as there was for easy c ... I understand that labview will not be as easy as easy c, but that it will be more involved, in depth and tweakable. Also, will there be a labview gui written with some express vis for features like motor control and sensor use as there was with easy c, or will we need to ...
Sample, or starter code will be provided in both C/C++ and LabVIEW. We will also provide Examples of how to read from sensors and interact with other elements of the kit.
As for comparing LabVIEW and EasyC, I suspect a thousand people will give a thousand answers. The documentation will explain how to do things in both languages, and you can make your own path.
Greg McKaskle
Unread 16-06-2008, 12:51
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Greg,
On The FIRST Community website, the tutorial: "NI CompactRIO Project and Building Source Distributions" refers to adding Targets. As I read it, this requires LabView Real-Time or one its sister programs. Will we be able to download a module to our existing LV 8.5 to enable us to do this?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 16-06-2008, 21:10
I suppose this could be supported, but the general idea was to provide a LV851, the realtime module, and some other modules such as vision.
But of course this will not be made available until FIRST is ready to release the kit.
Greg McKaskle
Unread 16-06-2008, 21:37
Jon236's Avatar
AKA: Jon Mittelman
Rookie Year: 2000
Greg McKaskle
There was talk about a control system release prior to Kickoff. Would that include LV851 and the real-time module?
Jon Mittelman
Unread 17-06-2008, 00:45
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Yes. Any early released hardware will most definitly come with the software and examples required to make it more than an expensive paper weight.
-Joe
Unread 02-07-2008, 21:50
Jon236's Avatar
AKA: Jon Mittelman
Rookie Year: 2000
Working with LV 8.5 and the NXT Toolkit, I am having some issues trying to use a Bluetooth dongle. I have no problem linking the NXT with my PC; it's just the connectivity with the LabView examples provided.
Does anyone have a solution they could share?
Jon Mittelman
Unread 02-07-2008, 22:13
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Yes, you will still be able to write all your code for the new controller as plain text. Just note that you will be using Eclipse, which IMHO is much superior to MPLAB.
Last question.
Don't worry, the new software development options for both coding in C++ and working with LabView should make it easy to start getting advanced results.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Help with programming new controllers, please. Oumonkey Programming 6 30-11-2006 21:53
is the 2004 user interface compatible with the 05 RC? wildabyss Control System 5 22-02-2005 05:28
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
White Paper Discuss: Using an Operator Interface with the 2004 EDU RC CD47-Bot Extra Discussion 6 20-01-2004 21:11
Tcl/Tk Programming Interface ebaer Programming 3 29-01-2002 12:46
