Go to Post its ok to have opinions- but why attack everyone elses who differs. - stevek [more]
Unread 16-06-2008, 18:21
speedtronic speedtronic is offline
Junior Member
speedtronic is an unknown quantity at this point
T/F Differential Protection
Can differential protection operate while its only one side is energized or being energized (HT side in this case)? When trying to energize a 132/11KV t/f from HT side when its differential protection operated while its LT side breaker was still open? Was it because of starting inrush current or t/f tap position?(It has an auto tap changer on HT side & while it was being energized tap position was on negative side)
Unread 17-06-2008, 08:02
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: T/F Differential Protection
Speed,
It would help to use full words instead of abreviations. I believe what you are asking about is differential protection schemes for high tension (HT) transformers (T/F). I am just guessing on this one, but with the low side (11kV) open, initial closing of the high side breaker could have any of a number of conditions present. Theoretically inrush current would be at a minimum but for the time following the closure of the high side breaker, the core structure would have substantial ringing due to the no load condition. This would reflect some rather interesting waveforms back to the differential sensors and would likely be detected as a fault. This would be a question better asked of the software engineer that designed the controls. In normal (loaded) operation, I would suspect internal arcing (fault condition) to produce similar waveforms.
It is also possible that without a load, the tap selector may have tried to adjust for output voltage. This "hunting" would have also introduced waveforms that could be interpreted as fault conditions.
Al
WB9UVJ
www.wildstang.org
________________________
pic: Team 34 - Differential Ed Sparks Robot Showcase 13 25-02-2008 10:15
Differential? Darunada Technical Discussion 27 13-01-2008 16:04
VEX Differential RoboticEngineer Programming 8 23-02-2006 00:40
4x4 software differential archiver 2000 13 24-06-2002 00:21
