Go to Post You will find that most people in good companies are real people that share the same values and concerns as all of us. - ebarker [more]
Unread 17-06-2008, 10:27
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
IFI Operator Interface Power Consumption
I was reading this thread and was wondering if anyone has ever measured the current draw of the IFI Operator Interface? The AC adapter can deliver 1500 mA max, but I'm interested in the average draw. It will vary depending on how many joysticks are hooked up; a ball-park number is all I need.
Unread 17-06-2008, 10:50
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: IFI Operator Interface Power Consumption
I'm at robotics right now and just checked it on our 08' controller. It was pulling 1/20th of an AMP (0.05) average. I'm sure it could fluctuate a little depending on how many potentiometers and LED's you have attached, but not that much.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 17-06-2008, 11:43
AKA: David Yanoshak
Rookie Year: 2007
Thanks!
Unread 17-06-2008, 12:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Ryan,
Were you measuring that number with the OI on the power supply, radio connected on OI and Robot and generally everything working? I can't imagine even our dinky short range radio modems drawing less than 50 mA when transmitting. And it should be transmitting almost constantly while the robot is running, provided you're talking over radio and not tether. So really, I was expecting at least 200 mA or so while everything's running.
Also, how did you measure the current anyways? I mean... I'd willingly cut and strip one of the power supply leads to discover this, but only because we've got half a dozen now and really need less of them at this point.
EDIT: Per Joe below, my expectations above are that you're measuring on the output (9V) side of the power supply.
Unread 17-06-2008, 12:32
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Is that on the AC side, or the output of the power supply? I'm assuming it's probably the input, so that would be 6W input. If we assume 50% efficiency (no idea how accurate that is), you'd have 330ma 9vdc.
Unread 17-06-2008, 17:52
RyanN's Avatar
RyanN
That was on the DC side with everything connected. It may be the meter though... I don't like the ones at the school. But I can take a picture if you like...
I measured it very carefully too (Going to Kevin). It wasn't the most ideal solution, but something quick, easy, and cheap. I stuck the probe of the multimeter into the center hole of the adapter (don't take that the wrong way either ). Then I used some wire that was around the classroom and hooked it straight from the outside of the adapter plug and touched the exposed metal on the OI end. I touched the other probe to the back of the plug on the OI. Hopefully that all makes sense.
Again, I believe the meter is giving bad readings (it's some off brand one that the state gives the school for their techapp classes.)
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 17-06-2008, 21:15
RyanN's Avatar
RyanN
I'm going to bring my trusty old RadioShack multimeter tomorrow to see what the actual consumption is. 50mA does seem very little now that I really think of it. Considering that the LEDs alone pull probably 5mA or more each, and there being like 20 of them... then the radio, and the CPU, the joysticks, and everything else.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 18-06-2008, 09:59
RyanN's Avatar
RyanN
Well I rechecked it with my RadioShack multimeter and it said .001AMP... so I know that's not right. Then I checked it with my Craftsman multimeter and had a more likable reading. Here is what it said: -0.41AMP.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 18-06-2008, 10:53
Rookie Year: 1998
That sounds like a much more realistic reading. Hopefully dyanoshak is still keeping up with this thread, as an order of magnitude difference might be a bit important to his plans. Kind of the difference between getting 3 hours of run time out of a dinky 9.6V 200 mAh NiMH vs. less than 20 minutes.
Given your readings, I'd probably budget for the OI drawing 1A if I had the space and weight in my project to be that conservative. Otherwise, I'd budget for 500mA just to give myself a little wiggle room in case you're still a bit off.
Unread 18-06-2008, 11:08
AKA: David Yanoshak
Rookie Year: 2007
I have been keeping up. 50 mA seemed low to me too; I was going to split the difference. Thanks to everyone for your measurements.
I wanted a ball-park number so I could pick out a reasonably priced NiMH battery to use during demos.
Unread 18-06-2008, 18:37
RyanN's Avatar
RyanN
I would also look into getting a higher voltage battery and a voltage regulator to step it down. Analog values have been goofy with me before while using two nine volt batteries in parallel. I hope you have better luck than I did.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 19-06-2008, 01:23
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Even though the AC adapter provides 9V, our team has used 12V batteries without any issues before (without a 9V regulator).
On a side note, using a battery to power the OI will void the warranty, but it is definitely nice not to have to plug in the OI all the time while testing the robot and getting everything working at a demo.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Last edited by Richard McClellan : 19-06-2008 at 01:24. Reason: added clarification
Unread 19-06-2008, 09:14
RyanN's Avatar
RyanN
I mean, what does not void the IFI warranty...
I believe a few years ago the controllers had 12V adapters, then last year they moved to 9V ones, but don't quote me on it.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
How would you power the operator interface Mikhail_Pham Control System 11 05-02-2008 13:34
What is the FRC Robot Controller Power Consumption amateurrobotguy Electrical 4 02-03-2006 00:23
pic: Portable Power Pack for Operator Interface CD47-Bot Extra Discussion 13 19-07-2004 03:02
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
operator interface power supply hi_im_sean General Forum 1 05-02-2003 14:50
