pic: Linear bearing rails: the Cheesy RAWC way
Re: pic: Linear bearing rails: the Cheesy RAWC way
Pretty, but................... What keeps it from pulling apart vertically?
They had two of these mounted exactly as shown, but mirrored so that the inside rails could be connected via cross members. Then the outside rails were firmly mounted to the drive train frame and cross-braced at the top. It required exact spacing at the top and bottom to be smooth, and I will conjecture that the force that pushed/pulled it up had to be almost dead center as well. If you got to see their model up close, it was smooth as butter and very lightweight.
From the CAD, I can see how it is restrained in two dimensions, but not the third. |
Any time anyone uploads a photo to CD Media it auto-tags the photo with 'frc###' (or 'ftc###') where ### is the Team Number in the profile of the uploader.
Try searching 'frc254' and 'frc968'. |
Thing is, there aren't any pictures of it on CD media... ill try uploading a few I have...
Please upload what you have. We are always trying to improve our lifts. I would love to see some that worked better than ours. |
my pictures are taken with a nice SLR they are over 2.0 mb!! aaa! ill try and crop / downsize them
#10
The outside is a plain 1x2 that makes a U frame, with the bottom being solidly attached to the robot base, and the top the open portion. The top is held at the correct width by a spanner that goes across the two beams. You can see this in pictures of our robot--it's the piece the pulley/flag holder/spring mounts to. The bearings then mount as you see here, top and bottom. The inside is a rectangle made of channel on the left and right sides, and 1"x2" on the tops and bottoms. it rides inside the bearings, as shown. |
#11
I think this is a "Picture paints a thousand words" situation. |
#12
This is the 2007 robot, by the way. The only difference is aesthetically the bearing mounts on the 2008 are prettier, and the 07 doesn't have the bearings at the top like the 08. To help with racking side to side in 07 we used teflon pads on the inside of the 1x2 uprights. For 2008 we added the bearings and removed the teflon. Last edited by Cory : 17-06-2008 at 18:28. |
#13
33 actually used some benchmarking off of 254 for our elevator this year. It was a really cool experiment in the importance of certain dimensional tolerances. While many dimension in this system can be reasonable, many have to be extremely precise. Too tight and the system will die a binding death. Too loose and it will beat itself to death.
Overall it was a very cool project, but tough on a mill without a digital readout. Definitely gave me additional respect for the POOFS craftsmanship. If you have never built an elevator it is definitely a good off season project to learn what is important. |
#14
Cory, thanks for the pictures. They're a little fuzzy but they confirm what I finally realized. I'm glad that you mentioned you were using Teflon as a glide surface. In some situations it makes perfect sense, this being one of them. It is also much easier to manufacture a Teflon glide that fits properly then it is to manufacture a bearing mount without access to a decent mill. |
#15
Actually our glides (254) for 2007 where simply adhesive backed Teflon from McMaster, they where really easy to manufacture, we just cut them out with scissors.
| pic: 294 Prototype Base frame rails | Borisdamole | Extra Discussion | 6 | 17-09-2007 18:19 |
| Looking for linear bearing solutions | Mona | Technical Discussion | 6 | 18-01-2007 19:40 |
| pic: Team 968 - RAWC - 2005 Robot | Travis Covington | Robot Showcase | 22 | 01-03-2005 19:40 |
| pic: Linear bearing + mount | Alex1072 | Robot Showcase | 6 | 02-02-2005 11:13 |
| RAWC in the news? | Greg Ross | General Forum | 9 | 07-09-2004 23:40 |
