| Thread Tools |
Rating:
Display Modes |
Can someone please help me with VEX Line Follower Programming. I don't understand it. I would appreciate it allot if someone sends me a code or gives information. Thanks.
Re: Help With Line Follower
The first step in programming anything is figuring out exactly what you want the program to do. Yes, you want to make a robot follow a line, but how will it do that? What kind of sensors does it have?
If you have one sensor that can detect when you are on the line and when you are off of it, the simplest (but not very efficient) method of following the line is to have the robot turn one way until the sensor leaves the line, then have it turn the other way until the sensor detects the line again. There are better ways to do this, however. Once you figure out what you want to do, then you can start writing code. |
http://www.chiefdelphi.com/media/papers/2019 We used EasyCv2, not Pro, but the application should be similar. The line follower sample program that comes with the Vex Programming Kit uses 3 sensors, which is more complicated than using one. I think it's easier to understand what you're doing if you start with just one sensor, move up to 2, and finally, try all 3. Last edited by ManicMechanic : 24-06-2008 at 11:24. Reason: incomplete |
You can open V2 programs in easyC Pro.
You may also want to check out www.vexforum.com allot of info there. |
| Line Following with PID | CircularLogic | Programming | 14 | 14-11-2006 13:15 |
| Vex line follower sensor kit program | jbill30 | Programming | 5 | 12-05-2006 14:43 |
| line seeking help needed | MisterX | Programming | 13 | 21-02-2004 19:42 |
| Help wiring Line sensors | magical hands | Electrical | 1 | 18-02-2004 10:17 |
