Is the maximum PWM value 254 or 255?
My team has always used 255 as the cut-off point for PWM values (otherwise things loop over), but whenever I look at example code I see others using 254. Why is this? Are the victors pre-calibrated to use 254? Do you get any more power by using 255?
Re: Is the maximum PWM value 254 or 255?
I've always used 255.
the difference should be absolutely negligibly though. |
The IFI system was designed to reset if it saw some series of values of 255, as I recall. Someone wiser than I in these matters will elaborate.
If 127 is truely exact middle then 254 should be max. In reality, I don't know. Our team has used both values at different points in time with no noticable differences.
I've always calculated the PWM value as being 127±127, so I say 254.
If memory serves, pre-2004 RCs would disable the PWM port if it saw 255. 2004 up to now can use the full 0-255 range. A signed 8 bit number goes from -128 to 127 by the way.
-Jim |
Since everything in a computer is measured in binary. In this it is a char there fore is 8 bits so can hold 2^8 possibilities, or 256, however as with everything in programing start with zero so it holds any number from 0 to 255.
255 is max, as an 8bit number is 256, therefore 0-255. the victors also have a deadband of +/- 5 values, so anything from 122-132 should be neutral, but i'll still do 127 just to be sure
The IFI control system will not send a pwm value of 255. If you try to set a 255, it turns into a 254.
The historical reason for this is the design of the data packets between the OI and RC. Two 255s in a row flag the start of a packet. |
#10
Thanks Alan! That explains a lot; using 254 is also nice because then 127 is the true middle.
#11
There isn't any difference between 254 and 255 when used with a victor speed controller, in fact, there isn't any difference between 255 and 233. See this post on the IFI forum: http://www.ifirobotics.com/forum/viewtopic.php?t=317
Also notice that at the default calibration, the real center is 132. |
#12
Look at the attached chart. The PWM input is x-axis, and y-axis is estimated output (%) based on these figured from IFI:
#13
Are the PWM values valid for the new operating system?
#14
I think these values are valid for the new operating system because I believe that the new operating system will be using the same victors from IFI.
#15
from what I've read about the new control system(and anyone is free to correct me), it will be using the same Victors as previous years and therefore the 8 bit 0-255 range would still be valid
I apologize if I just restated everything that was already said... I just thought I'd get my 2 cents in |
| Robot Controller reset issue when pwm value changes | wt200999 | Programming | 4 | 04-01-2008 22:15 |
| Maximum PWM length | mechanicalbrain | Electrical | 5 | 13-03-2006 23:18 |
| Dividing PWM value - easy question | jgannon | Programming | 1 | 04-02-2004 22:57 |
| Encoder Counts/time period to PWM value | Zee | Programming | 10 | 04-02-2004 01:41 |
| Why can't you use 255 in PWM? | Andrew | Technical Discussion | 4 | 29-05-2003 14:50 |
