Go to Post I would like to know the team simply because it seems they could use a hug. - Taylor [more]
Unread 24-06-2008, 19:44
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Need help to find a tool, kinda urgent
I need help in finding a machine/tool that will cut sheets of aluminum to a certain size, Thanks in advance
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 24-06-2008, 19:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Need help to find a tool, kinda urgent
There are many different machines that can do this depending on the application. Perhaps you can describe in more detail what you are trying to do.
Unread 24-06-2008, 19:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Some helpful information would be:
How thick is the aluminum?
How large are the sheets?
What shape do the cut out parts need to be?
Unread 24-06-2008, 20:01
R.C.'s Avatar
i mainly need something to cut out at the most 1/2 inch aluminum sheets. The maximum size would be like 27 x 37 sheet. The shape would be rectangles or squares.
R.C.
Unread 24-06-2008, 20:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
That's no small task.
If it was like 1/4" or under you could get it sheared.
Something that big, you're not going to have a lot of options. How many do you need? If it's a one off, just order it cut to size from your local supplier. There's really no easy/safe/cheap way to do what you want on your own.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-06-2008, 20:07
MrForbes's Avatar
AKA: Jim
I don't have any experience with one, but first thing I would do is to try to find someone with a good sized plasma cutter....
Unread 24-06-2008, 20:10
R.C.'s Avatar
Cory a 1/4 would be fine also
R.C.
Unread 24-06-2008, 20:12
MrForbes's Avatar
AKA: Jim
It would take a very strong shear to cut 1/4" aluminum sheet. Not likely to find one in most shops.
Unread 24-06-2008, 20:16
R.C.'s Avatar
the reason i said 1/2 inch is our physics teacher needs it for his summer project and i said 1/4 because cory said it would be possible. But we need it for an 1/8 inch aluminum. I was trying to get a 1/2 so everyone could use it. But an 1/8 would be fine also
R.C.
Unread 24-06-2008, 20:48
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
Well, if you want to cut 1/2" or up to a foot or so, just buy a waterjet for the "cheap" ones I think its in the 80-90k range.
2053 Alumni
Unread 24-06-2008, 21:11
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
It's probably best if you take a step back and tell us what you are trying to do.
Are you wanting to end up with a sheet of X thickness 27 x 37 as the final product (those dimensions make me think it is for a base)? Or are you wanting something about that size that you will cut/finish with some other process?
What determines the thickness? and what are you using this for?
EDIT: reread some posts... So, you are just looking for a machine to cut those thicknesses in general?
Cory's Avatar
AKA: Cory McBride
For sure. You'd have to find a shop who could do it.
If you only *need* to shear 1/8" aluminum, you could buy one for a reasonable price to do so yourself.
If you need to accurately cut something any thicker than that, you need to find someone else with specialized equipment to do it for you.
2001-2004: Team 100
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
URGENT! We need help with the accelerometer lkdjm Technical Discussion 0 08-02-2005 14:35
Need help with Data recovery [urgent] plutonium83 Chit-Chat 7 11-01-2005 10:35
need some urgent help (REPOST) archiver 2001 1 24-06-2002 01:01
URGENT: i need help!!! Ydnar 3D Animation and Competition 4 14-03-2002 22:37
