Need help with mini motors
![]() Couple questions? How did you use this? Can you press or put any pinions or spur gear on this? Is there any way to use these? We have a lot because teams have given us these and we have about 12 of them. |
Re: Need help with mini motors
If I recall correctly, they have two threaded holes on the face for mounting.
As for a pinion, You can press a gear onto the shaft if it has the right bore size for a press fit. I think that would be just a few thousandths undersize, but I'm no expert in that. You can buy a gear with bore below that and open it up on a lathe, or you can turn a custom one from gear rod. You could also buy a gear with a hub and set screw with a bore size the same as the shaft. Although set screws are not a good way to mechanically fasten the pinion to the shaft. As for usage, I've only seen teams use them as a tachometer and I have to see a team power a system with them. I'm sure some have, I just haven't seen it. It's not terrible powerful, so there aren't many applications for it. |
i'm sorry i just remembered that banebots has all the small mini motors in a planetary gearbox
Yes, they do. You can only get the gearboxes with them already in.
They make for good rollers I hear. ![]() -Vivek EDIT: At 2 dollars a pop, they are pretty cheap. |
We used this little motors for our drive base. They offered plenty of power and made us one of the fastest robots on the field. We never had trouble with them. They're strong enough to pull my car! This little motors really amaze me with their efficiency, strength, and weight. There has never been a better motor in FIRST.
All jokes aside... yea... I'm not sure what use these motors could have. Possibly put a small fan on the end of them to keep something cool? We've never used the large fans they provide in the kit either, nothing ever gets hot enough to need them. We did use a small muffin fan to cool a FP motor down. |
Those were the 36mm gearboxes with the much more powerful RS-540 motors though.
But with what EricH said, the motors on the small BaneBots are very strong. In fact we used this motor for our arm last year (2007). However, we did manage to burn it out a few times when we accidently stalled it in the pit and in the workshop. This year's fork mechanism involved a more complex and intricate system involving a FP motor, its gearbox, a muffin fan, a servo, and the tread that came with our test AM Performance wheel, some aluminum tube, 1/4" aluminum plate, a 10 turn potentiometer and about ten hours or more of work. What we ended up with was a very nice wench system that worked flawlessly all season. |
I'm telling you, these things look like they would make wicked rollers.
With a reduction to around 800 rpm, they have 190 oz-in of torque and with the 28mm gearbox, they end up at a weight of 5.1 oz with the gearbox! These would be really useful in a manipulator because of their relatively high power density. -Vivek |
#10
The conclusion I've derived is that with a 20:1 gearbox this motor was ideal enough to pick up the tubes in '07 and 1-2 poof balls at a time in '06 if your bot drove 6ft/sec or less. I agree that they're great power for the small size and weight in these years. |
#11
With the 16:1 reduction, it is at 1000 rpm or 16.7 rps. 4*Pi=12.5" or one foot. So that is a surface speed of 16 fps easily right? We have supports under the ball and these rollers on the sides of the ball (near the middle) so it is not like the rollers would be supporting the weight of the ball directly. We pick up off the ground. All of your points are valid though. -Vivek |
| HELP EMERGENCY WITH FISHERPRICE MOTORS | Team2441 | Motors | 5 | 16-02-2008 22:42 |
| questions on window motors!!!!! need help! | nwbutterfly | Motors | 4 | 19-01-2005 18:01 |
| Some help with motors | Bharat Nain | Technical Discussion | 2 | 05-03-2004 19:29 |
| Window Motors. Need help!!!! | Mohsin | Motors | 1 | 27-02-2004 13:05 |
| hey need some help with writing a code please help me here | magical hands | Programming | 9 | 01-01-2004 21:46 |
