Go to Post You should qualify the same way you eliminate if you ask me. - sircedric4 [more]
Unread 09-07-2008, 21:40
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Is your frame tough enough for FIRST?
I was cadding up our last years frame up and a thought hit me. How many pounds of force actually hits your bot? Weak hits, medium hits and the hardest hit possible. So i need some help finding out the forces.
Thanks
CD
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 09-07-2008, 22:23
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Rookie Year: 1999
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: Is your frame tough enough for first?
I would like to think so... and hard, harder, and hardest
mike d
See Ya
Unread 09-07-2008, 23:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The speed at which the collision occurs, as well as the angles and location of the hit, and how effective the bumpers are, etc will play a big part. For weight, figure 150 lbs to make it easy.
Some materials absorb impacts better than others...for example, fiberglass tends to bounce back, while some aluminum shapes get bent easily.
Unread 09-07-2008, 23:50
R.C.'s Avatar
Thatz what i was figuring, but i wasn't sure. What do you think composite sides
R.C.
Unread 09-07-2008, 23:57
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
I don't know the forces involved, but there are dents on the front of our robot that would be tough to make with a hammer.
2016 Central Illinois Winner. Curie Division finalist
Unread 09-07-2008, 23:59
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Our hardest hits this year were when hybrid went awry. 15 ft/s into the wall is tough. Turns out the wall is a flexible member. Other than that, bumpers help a lot. We have some pretty vicious scars from years past.
As a little bit of how bad can it really get, I recently saw a vehicle go to 10 G's during a 5mph impact with a wall. 15 ft/s is almost 10mph. For a little math let's assume that your robot collides with a stiff wall at 3 m/s (approximately 10 ft/s). bumpers are about 3 inches thick or rough .1m Let's assume the bumpers are perfectly balanced and do an ideal deceleration.
Therefore d=V*t-1/2at^2 which is really d=V*t-1/2*V*t therefore d=1/2Vt
or t=2d/V=.2/3=1/15 second.
V=at therefore a=45m/s^2 or about 4.5 G's. This would be if the bumpers had perfect crush causing constant deceleration. If you assumed a linear rate of decel from 0 then the peak will get closer to 10G's. You can continue playing this game and second guessing it quite a bit. Overall having it survive a 10 G impact is probably pretty reasonable. You shouldn't see a lot of those, but you may likely see a couple a season.
Unread 10-07-2008, 00:03
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
I agree, those robots can take a beating! But, no matter how many numbers you run, your probably never come close to those freak incidents. So, always throw in a hefty safety factor.
Unread 10-07-2008, 00:06
R.C.'s Avatar
We didn't use bumpers our 07 season and all the chassis aluminum is bent in.
R.C.
Unread 10-07-2008, 08:12
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
One thing to keep in mind is that dents and dings aren't always a bad thing. They absorb impact energy that could go elsewhere. If your robot is still fuctional consider it good energy management. If your robot was incapacitated. Make it stronger.
Unread 10-07-2008, 12:17
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
Rookie Year: 2000
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
we did our robot with an 80/20 frame this year.. the same chassis lasted from NJ to Chesapeake to atlanta. our hardest hit was in atlanta first elimination match our autonomous goes crazy and we hit the wall soo hard the entire wall is moved... the bumpers arent there our robot steering mechanism is toast... turns out the force angled one of the beams so the connecting point to the main chassis went from 90 degrees to say 65-70... neways our robot weighed 130 with bumpers and top speed which is what it hit the wall at was 25fps.
other than that the 80/20 frame has held up very well.
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
Unread 10-07-2008, 14:28
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
Team Role: Coach
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
Squirrel from 1726 can attest to the toughness if 1662's frame. We were pretty busted up in 05 & 06. We totally redesigned the frame. We have ran it into a wall at full speed to test it. It passed. Pic is on CD
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 11-07-2008, 21:44
SlaminSwimster's Avatar
SlaminSwimster SlaminSwimster is offline
FRC #2614 (MARS)
SlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant future
Re: Is your frame tough enough for FIRST?
I'm not sure about force, but at the Pittsburgh regional hitting another robot caused our 1/4 in plexi to shatter into 5 pieces.
You can sleep when your dead - Warren Zevon
Imagination is more important than knowledge -Albert Einstein
Unread 11-07-2008, 22:29
R.C.'s Avatar
oooh, any pics?
R.C.
Unread 11-07-2008, 23:52
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Was the "plexi" acrylic or polycabonate (Lexan)?
The reason I ask is that while they look similar, acrylic can shatter like glass, whereas polycarbonate is much stronger and normally it should never shatter (unless you spill Loctite on it). The only "downside" to polycarbonate is that it is more expensive than acrylic.
On both the teams that I mentor, acrylic is almost never used on a FIRST robot with only a few very limited exceptions, as polycarbonate is the preferred "plexi" material.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
  #15   Spotlight this post!
Unread 12-07-2008, 06:53
Billfred's Avatar
Billfred Billfred is offline
For the good of the order (since I can't think of any such cases), what are those limited exceptions where acrylic is used? (1618 used it as side panels its rookie year, but wised up quickly following that.)
What is your frame weigh? RTTComanche17 General Forum 8 09-01-2008 11:05
Future of Education: Tough Choices or Tough Times Rich Kressly Math and Science 0 21-12-2006 09:10
pic: Tough cookkie frame Tytus Gerrish Extra Discussion 15 31-07-2006 12:48
pic: How heavy is your frame? rees2001 Robot Showcase 10 18-02-2005 22:38
