Go to Post If said device costs 10x more to manufacture than a simpler solution integrating COTS parts, and only performs 10% better, that's poor engineering. - Cory [more]
  #16   Spotlight this post!
Unread 12-07-2008, 10:32
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Is your frame tough enough for FIRST?
Originally Posted by Billfred View Post
For the good of the order (since I can't think of any such cases), what are those limited exceptions where acrylic is used? (1618 used it as side panels its rookie year, but wised up quickly following that.)
We used acrylic last year to cover up our electrical board. Lexan would probably have been better. The plexiglass cracked due to improper hole drilling. It worked though. If you saw last year's robot you would understand.
-Vivek
EDIT: Our frame has always been plenty strong for us. I don't care what anyone says, the kitbot frame is a beast.
"we don't build robots, we build people"
  #17   Spotlight this post!
Unread 12-07-2008, 11:56
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
We used the kitbot frame this year and it held up well. The frame suffered virtually no damage, but our bumpers sure got ripped up at the Kettering Rookie Competition (the judges at Buckeye were very surprised by how much damage we had from it; it was brutal, and we were tipped a few times with no penalty called).
However, I know it can withstand a good blow without bumpers since I was test driving it after we/I got the drive code running, and I went in full reverse . . . into a metal column in our school lobby. The battery casement came off (secured with one screw at that time, but that was fixed), but the pole suffered a chip and the frame had no damage.
I cut myself shaving with Occam's razor.
  #18   Spotlight this post!
Unread 12-07-2008, 13:56
Doctorwho's Avatar
Doctorwho Doctorwho is offline
FRC #0467
Doctorwho will become famous soon enoughDoctorwho will become famous soon enough
On 467 we used a unibody design this season that used the skin to support the internal components without a frame. it worked pretty well as it was light weight and durable. It took the force of being flipped twice at the Connecticut
regional without any dents or damage, our bot was so light that we had to bolt
a 14.1 pound steel plate to the bottom to stabilize it.
Frame, pre-construction:
http://www.team467.org/gallery/main...._itemId=512177
Final Bot:
http://www.team467.org/gallery/main...._itemId=512365
  #19   Spotlight this post!
Unread 12-07-2008, 20:36
SlaminSwimster's Avatar
SlaminSwimster SlaminSwimster is offline
FRC #2614 (MARS)
SlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant future
Originally Posted by artdutra04 View Post
Was the "plexi" acrylic or polycabonate (Lexan)?
The reason I ask is that while they look similar, acrylic can shatter like glass, whereas polycarbonate is much stronger and normally it should never shatter (unless you spill Loctite on it). The only "downside" to polycarbonate is that it is more expensive than acrylic.
On both the teams that I mentor, acrylic is almost never used on a FIRST robot with only a few very limited exceptions, as polycarbonate is the preferred "plexi" material.
I'm pretty sure it was polycarbonate but i'm not sure. It didn't shatter exactly but it cracked apart.
You can sleep when your dead - Warren Zevon
Imagination is more important than knowledge -Albert Einstein
  #20   Spotlight this post!
Unread 12-07-2008, 20:45
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
Good way to distinguish between polycarbonate and plexiglass:
Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate.
-Vivek
  #21   Spotlight this post!
Unread 12-07-2008, 21:56
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Or try to cut it with a jig saw and if it cracks then its plexi
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
  #22   Spotlight this post!
Unread 12-07-2008, 22:45
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
-Vivek
Haha. Real efficient Vivek... I like it.
We used acryllic as our electrical panel. We have a laser on campus that we can use to cut acrylic which takes the error out of drilling holes. We can model it up exactly as we want the board in CAD and then send it straight to the laser. We can even do etching with it if we want.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
  #23   Spotlight this post!
Unread 12-07-2008, 22:59
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
190 used an acrylic tube for the inside of its custom built high power slip ring, because we needed a plastic tube with an ID equal to the OD of the aluminum tube used for the elevator. This piece of acrylic was merely to mount the copper rings on and to act as an insulator.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
  #24   Spotlight this post!
Unread 13-07-2008, 00:41
AndyB's Avatar
AKA: Andy Burchardt
Low impact areas where cost is a factor. Electrical panels, covers, etc... are great uses for acrylic.
  #25   Spotlight this post!
Unread 13-07-2008, 00:49
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
I would assume acrylic is a lot more common for rookie and some of the less better off teams because of the inexpensiveness and availability as compared to acrylic.
Heck, I hadn't even heard of the goodness that is polycarb until this year and we have yet to use it outside of the toughboxes on our bot.
-Vivek
  #26   Spotlight this post!
Unread 15-07-2008, 17:09
fuzzy1718 fuzzy1718 is offline
MTU class of '15
Rookie Year: 2007
fuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant future
Everyone is talking about aluminum and plexiglas, does anyone use an all steel frame other than us?
What FIRST has taught me:
Money is not everything.
In order to change a culture one must change the hearts of the next generation.
The fish rots from the head down.
Why we do something is often more important than what we do.
Repeated success is often sown on the backs of a few, but reaped by many.
  #27   Spotlight this post!
Unread 15-07-2008, 19:14
Doctorwho's Avatar
FRC #0467
Steel, while being very durable and relatively inexpensive is heavier than aluminum and polycarb. Most teams prefer these alternative materials because it gives the a larger weight allowance for other parts of the robot such as the drive train or the manipulator
  #28   Spotlight this post!
Unread 15-07-2008, 19:18
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
I believe both 269 and 1501 have used welded thinwalled (.035" sounds about right iirc?) chromoly tubing for frames before. \
The thing is, to get steel tubing to be light enough, it has to be very thin. This makes it a lot harder to work with in general.
  #29   Spotlight this post!
Unread 15-07-2008, 19:24
R.C.'s Avatar
Yeah i prefer to use aluminum tubing instead of steel.
R.C.
  #30   Spotlight this post!
Unread 15-07-2008, 19:50
AKA: Nicholas
I believe we had a significant amount of steel on our superstructure... someone on our team decided it was a good idea. Next year I'll be pushing for a lighter material: we barely came in at 119.2 after lightening, but it was 119.9 before elimination rounds.
What is your frame weigh? RTTComanche17 General Forum 8 09-01-2008 11:05
Future of Education: Tough Choices or Tough Times Rich Kressly Math and Science 0 21-12-2006 09:10
pic: Tough cookkie frame Tytus Gerrish Extra Discussion 15 31-07-2006 12:48
pic: How heavy is your frame? rees2001 Robot Showcase 10 18-02-2005 22:38
