Go to Post Of course this should be your decision- not the FIRST community's. Take charge of your destiny. - Wayne C. [more]
Unread 14-07-2008, 18:20
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Use MPLAB to program your VEX robot -- FOR FREE!!
I made this really nice tutorial that will show you how to program your vex bot with MPLAB. You can download it from here.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 23-07-2008, 12:44
Aaron S's Avatar
Aaron S Aaron S is offline
FRC #1612 (Robosharks)
Aaron S is an unknown quantity at this point
Send a message via AIM to Aaron S
Re: Use MPLAB to program your VEX robot -- FOR FREE!!
Thanks for the tutorial, I was getting tired of using EasyC and this also helped me get MPLAB up and running properly.
Unread 26-07-2008, 17:47
GGCO's Avatar
AKA: Grant
FRC #3357
Not a problem.
The FIRST Alliance
COMETS Robotics
Website
Unread 26-07-2008, 20:28
Aaron S's Avatar
I've actually just gotten a chance to load the hex file onto a controller and it seems that it doesn't run once loaded. I put a PrintToScreen at the beginning of main and when I turned on the controller while it was tethered, I got nothing. To make sure it wasn't a problem with the way I was transferring the hex file I compiled the same thing in EasyC and loaded it onto the controller, which proved to work fine.
Can you think of anything that could be the problem? I followed the tutorial exactly and I get one warning in the compilation output about calling Tank4 before it was prototyped, but asides from that everything seems to be fine.
Oh and I'm using MPLAB v8.10 with MCC18 v2.4 if that helps.
Unread 27-07-2008, 08:00
GGCO's Avatar
AKA: Grant
FRC #3357
That is really weird. I will look into it, and get back to you later today.
The FIRST Alliance
COMETS Robotics
Website
Unread 27-07-2008, 08:09
GGCO's Avatar
AKA: Grant
FRC #3357
Aaron,
Make sure that you have the correct linker/.h/.lib files. That is the only think that I can think of unless your code is incorrect. Why don't you post it just so to make sure. I'll do my best.
The FIRST Alliance
COMETS Robotics
Website
Unread 27-07-2008, 21:38
Aaron S's Avatar
Before I post the code I've been working on (which was loaded onto the robot initially) I'm going to try and load just a simple PrintToScreen in the main function to see if it was my code. However, I can only do that tomorrow as that's when I get to go into my school and toy around with it.
I'll let you know anything I find out, thanks for your time.
Unread 28-07-2008, 18:44
Aaron S's Avatar
It turns out the controller I had loaded the code onto was broken in some way, but it's fixed now (after loading the default FRC code, then the Default Vex code). I loaded my new program onto it and it worked perfectly, thanks.
Unread 07-08-2009, 08:51
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
GGCo i have downloaded the files etc from your tutorial
but get an erro message of not finding stdio.h
?? if yoiu can help that would be great
thanks john
Unread 07-08-2009, 16:48
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
Rookie Year: 2007
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
PrintToScreen should only work in EasyC, as far as I know. For the IFI Loader terminal window, use printf(). Cast the string with (const char *), as follows:
Code:
printf((const char *)"Hello, world.\r");
Unread 07-08-2009, 20:21
MarkO's Avatar
MarkO MarkO is offline
AKA: Mark D. Overholser
FRC #0957 (WATSON Robotics team)
Rookie Year: 2007
MarkO is an unknown quantity at this point
Code:
EasyC uses the WPILIB.. That is what GGCO's Document is all about...
Here is my Follow Up Post on how to fix that issue, Re: Use MPLAB to program your VEX robot -- FOR FREE!! (Post #18).
Unread 10-08-2009, 16:14
daltore's Avatar
AKA: Aaron Osmer
Rookie Year: 2007
I know this is talking about WPILib, that's what I used in MPLAB (well, an MPLAB clone, anyway) for a while before switching to default code. I was under the impression that PrintToScreen only worked with the EasyC reader, not with IFI Loader, because it sends more data than IFI Loader is looking for (specific line numbers, line resets, etc.). I've always used printf() and it works. But you can use PrintToScreen?
Unread 25-10-2010, 11:14
eagal eagal is offline
eagal is an unknown quantity at this point
hello GGCO ,
i used your tutorial ( he is great ) but i'm getting one eror :
he goes like this :
Eror: coff file format for '. main.o' is out of date
link step failed
i hope you can help me with that ...
thank ,
eagal.
Unread 25-10-2010, 11:19
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
That means your compiler version doesn't match the libraries you are using. The libraries were compiled with one version of the compiler and your program is being compiled with a significantly different version.
The COFF format changed when the compiler went from version 2.x to version 3.x.
Figure out what version of the compiler you're using and you can get the matching support libraries.
P.S.
Kevin Watson's site has basic libraries for both the 2.x and 3.x compiler versions.
What program should I use for website design? radioshackkid Website Design/Showcase 35 03-02-2007 22:12
Which wheels will you use for your robot this year? GO Groves 1213 Technical Discussion 44 03-02-2007 12:36
Announcement: Free CAD for Vex swe9 VEX 1 25-09-2006 04:00
How do you program your vex? CircularLogic FIRST Tech Challenge 4 01-05-2006 16:51
What program do you use for webdesign? Rez648 Website Design/Showcase 42 24-05-2004 17:19
