Go to Post Being inspired is a lot like learning, not everybody does it the same way. - Jay Trzaskos [more]
  #16   Spotlight this post!
Unread 21-07-2008, 16:05
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
Re: Acrylic Gearbox Sideplates
I know 254/968 used delrin. I was utterly amazed at their gearboxes a year ago at champs during my rookie season. I am still utterly impressed although (slightly) less incredulous. Lexan is a material our team has used a lot. In my opinion, its a great material and its never cracked for us, which is great. We've bent .25" thick pieces back to touch the other end of the 3'ish long piece and it just shot back into form.
2053 Alumni
  #17   Spotlight this post!
Unread 21-07-2008, 16:28
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Maybe you could use some of this surplus MIC-6 aluminum jig plate in 5/16" or 3/8". The price is right: http://www.sandsmachine.com/alumweb.htm
The deal with jig plate is that it doesn't do funny things like warp like crazy when you machine it - it is very stable compared to regular plate.
Someone near Roseville, CA ought to get S&S Machine as a sponsor!
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #18   Spotlight this post!
Unread 21-07-2008, 16:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by tennispro9911 View Post
This may or may not be the right place for this question, but for Transmissions, what are people's opinions on the pros of cons of Polycarbonate vs Delrin vs Aluminum.
Steel is best!
  #19   Spotlight this post!
Unread 21-07-2008, 19:21
Dick Linn's Avatar
no team (Synergy)
Actually, cast iron is probably better for transmission casings. Doesn't do much for gas mileage, though.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #20   Spotlight this post!
Unread 21-07-2008, 19:28
NickE's Avatar
NickE NickE is offline
_
FRC #0254 (The Cheesy Poofs)
NickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond repute
from what i've seen, delrin works fine if you keep it solid (no pocketing)
if its just a solid sheet with only necessary holes cut out, it should work fine
  #21   Spotlight this post!
Unread 21-07-2008, 19:42
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
I definitely wouldn't recommend acrylic for most robot applications, but I did recently have the chance to work with both cast and extruded acrylic.
I found the cast acrylic to be closer in machinability and performance to polycarb and it is significantly cheaper.
A call to you local plastics supplier can offer lots of insight and alert you to materials that you may not know about.
My local supplier here in Michigan is Total Plastics.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Gearbox pt 2 bobdahaxor Technical Discussion 14 22-12-2007 11:24
Gearbox bobdahaxor Technical Discussion 1 13-12-2007 19:34
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Gearbox Lord Nerdlinger Motors 20 15-07-2003 00:38
Gearbox ZACH P. Motors 4 09-02-2003 20:14
