Go to Post No one can deny the awesome power of FIRST. - Queen_of_Mascot [more]
Unread 28-07-2008, 18:10
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
Team Role: Mechanical
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
segway project: where to get torsion springs (around 20-40ft/lbs)
So i've been building my own segway for a bit now, and i'm making a lean steer mechanism for my steering using a torsion spring. I'm trying to look for places where i can get some pretty strong torsion springs, but the most powerful ones i can find are around 40in/lbs, which isn't nearly enough.
Here are pic of the segway and lean steer cad.
anyone know of a good place to get something like this? or maybe even a better design for the steering.
--danny
(for the lean steer cad, there is a stop at the top in between the two fingers comming from the spring. the blue cams are attached to the shaft, so only one side of the spring is extended at a time.)
ID:	6752  Click image for larger version
Name:	spring mechanism.jpg
Unread 28-07-2008, 19:48
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: segway project: where to get torsion springs (around 20-40ft/lbs)
You could look for garage door springs. I'm not sure how strong they are, but I'm guessing they have at least your 40 ft*lbs.
Unread 28-07-2008, 23:06
dfukuba's Avatar
Technical Advisor
AKA: Daniel Fukuba
The problem with that is garage door springs are many feet long. I want this to be something that would be around 4in long max.
Unread 28-07-2008, 23:15
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Try cutting one shorter and measuring how strong it is?
Unread 28-07-2008, 23:19
Also, torsion springs can (should?) only be "torsioned" one way, afaik. i'm assuming you want to turn both left and right?
Unread 29-07-2008, 11:42
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Here's a torsion spring calculator: http://www.engineersedge.com/calcula...spring_pop.htm There are a couple links to spring suppliers as well.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 29-07-2008, 11:55
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
i have a question about your segway are you using first parts to power the wheels like tough boxes and cims.
Unread 30-07-2008, 17:48
dfukuba's Avatar
Technical Advisor
AKA: Daniel Fukuba
The spring will only be "unwound" from one end at a time. there will be a stop at the other end, while one of the cams rotate the end of the spring.
the scooter uses npc t-64s with a123 batteries 4p10s.
i have found "machined springs" made by heli-cal. They look pretty sweet, they actually have a hub on both ends of the spring. that would be a wonderfull way to make the mehcanism, but i would need to find someway to get one with out ordering in bulk.
Unread 31-07-2008, 07:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Call them and ask them if you can get a sample of two parts, and offer to pay shipping. Bet they say yes.
Springs?? (10 lbs. at 22 ft/s) KarateDog171 Technical Discussion 35 24-01-2008 18:37
where to get... Rickertsen2 Technical Discussion 1 18-02-2004 08:00
looking for a torsion spring tml240 Technical Discussion 1 03-02-2004 12:51
Torsion Spring Specs ateene Technical Discussion 0 22-01-2003 15:42
Can we really get 225 in-lbs from the drills? archiver 2001 2 23-06-2002 22:48
