Go to Post Robot? What robot?! - LightWaves1636 [more]
Unread 29-07-2008, 15:33
gohan22 gohan22 is offline
gohan22 will become famous soon enoughgohan22 will become famous soon enough
Almost balancing Scooter
visit http://www.youtube.com/watch?v=VLHPlXa6e3M to see the video.
I've increased Kp until i noticed vibrations and then back off
that....i added a delay at the end of the of the loop to also reduce
the vibrations, Currently the loop runs at 50hz. Then i added Kd.. if
set too high it causes the lithium ion battery to put out too much
current causing the battery to shut down.
So as you can see in the video there is a lot of oscillation at the
zero point and i don't see discontinuity. Any ideas of how to remove
them.. Also i noticed that once you pass a certain threshold the
motors cant bring you back to your zero point, did you face a similar
issue.
Thanks
Ahmed
Code:
#include<16f877a.h>
#DEVICE ADC=10
#fuses hs,nowdt,noprotect,noput,nobrownout
#use delay(clock=20000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8,pari ty=N)
int BIN (float x)
if (x==0)
return(0);
if (x>0)
return (1);
if (x<0)
return(-1);
void main ()
float angle=0,motor=0;
long lmotor=0,rmotor=0;
long gz_adc=0,ax_adc=0, ax_offset=516,gz_offset=494; /* Analog values */
signed long gz_deg=0,ax_deg=0,old_angle=0,new_angle=0;
long dt=0; // do nothing
int flag=0;
/*Setup PWM timers*/
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
setup_timer_2(T2_DIV_BY_4,82 , 1); //15KHz frequency of the motor
//setup_timer_0(RTCC_INTERNAL | RTCC_8_BIT| RTCC_DIV_256);
//sets up timer
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
//Setup the ADC
setup_adc(ADC_CLOCK_INTERNAL );//setup clock before setup
setup_adc_ports( ALL_ANALOG );
//Initialize the PWM to 0
set_pwm1_duty(0);
set_pwm2_duty(0);
delay_ms(3000);
while(1)
dt=get_timer1();
set_timer1(0x0000);
old_angle=angle;
//setup ADC for accel
set_adc_channel(0);
delay_us(10);
ax_adc=read_adc();
delay_us(60);
//Setup ADC for gyro
set_adc_channel(1);
delay_us(10);
gz_adc = read_adc();
if (ax_adc>=ax_offset){ax_deg=(((ax_adc-ax_offset)*14)>>5);
else { ax_deg=((((ax_adc-ax_offset)*14)*-1)>>5)*-1;}
if (gz_adc>=gz_offset)
{gz_deg=(((gz_adc-gz_offset)*41)>>6);
angle = 0.91* (angle + (float)(gz_deg*0.00000016*dt));
angle += 0.09*(ax_deg);
else { gz_deg=((((gz_adc-gz_offset)*41)*-1)>>6)*-1;
angle = 0.91* (angle + (((float)gz_deg)*0.0000016*(float)dt));
angle += 0.09*((float)ax_deg);
if (angle<0.6 && angle>-0.7)
angle=0;
else angle=angle;
//flag will be 1 if angle>0 and flag will be -1 if angle<0 and 0
flag = BIN(angle);
new_angle = angle;
//Calculate motor value for PD controller
motor=((4.3*angle)+(0.2*(float)(gz_deg)));
//Make sure the "motor" value does not exceed 250 or -250
if(motor>178)
motor=178;
else if (motor<-178)
motor=-178;
else {motor=(signed long)(motor);}
//Control the motors direction and set its PWM
/*makes sure that you remain forward or reverse and how we switch to reverse*/
/*if ((abs(new_angle-old_angle)>4) && (new_angle*old_angle)<0)
flag = -flag;
else
flag=flag;
if (flag=1)
motor=motor;
else
motor=(255-abs(motor));
//flag=1 => forward
if (flag==1)
rmotor=(long)((motor))+15;
rmotor=((float)(rmotor)*1.128);
lmotor=(long)((motor)+15);
output_b(0b10000000);
//delay_us(10);
set_pwm1_duty(rmotor);
set_pwm2_duty(lmotor);
// delay_us(50);
//Reverse
else if (flag==-1)
lmotor=(abs(motor)+15);
rmotor=(abs(motor)+15);
//rmotor=(long)(rmotor);
output_b(0b00000001);
//delay_us(10);
//delay_us(50);
else {
lmotor=rmotor=0;
output_b(0b00000000);
set_pwm2_duty(lmotor);}
old_angle = angle;
delay_ms(20);
Unread 29-07-2008, 22:21
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: Almost balancing Scooter
great job guys, we tried building a segway using a pic controller. We started out prototyping with the Vex controller, but there was too much "play" in the vex gears.
Unread 29-07-2008, 22:59
Thanks...almost there we just need to get rid of those vibrations.....im just out of ideas.
Unread 30-07-2008, 11:19
kajeevan kajeevan is offline
FRC #0188 (blizzard)
Team Role: Mechanical
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
unfortunately im not a programmer so i can help you but i would like to know about the specs on your segway like what motors and gearboxes you used and what speed your assuming it to run at because im looking into making my own homemade segway.
Unread 30-07-2008, 16:59
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Are you using a proportional algorithm, or PID?
Unread 30-07-2008, 19:01
right now we are using a PD
Unread 30-07-2008, 19:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by gohan22 View Post
...i added a delay at the end of the of the loop to also reduce the vibrations,...
Maybe you could do a "delay" in the other direction. Do a simple prediction of what the angle is likely be the next time through the loop, and use that as your feedback value instead of the current angle.
I didn't look closely enough at your code to be certain, but are you sure you have the right sign on your Kd term? It should act to reduce motor speed, but you describe it as causing more current to be drawn.
Also, are you using Victor speed controllers? They have a dead band around the neutral point that makes them a bit unsuited for applications requiring the motors to hold a given position. If you're very careful, you can account for the dead band in software, but you have to make sure everything is appropriately calibrated.
Unread 30-07-2008, 19:24
Im using OSMC to drive my motors and using a pic16f877A for the control.
Unread 01-08-2008, 08:44
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Toyota may be beating you to the punch:
http://jalopnik.com/399664/toyota-re...istance-robots
Toyota brings a Segway to the masses.
Unread 01-08-2008, 11:48
acdcfan259's Avatar
acdcfan259 acdcfan259 is offline
Brainssss....
AKA: Jake Carroll
FRC #1027 (Mechatronic Maniacs)
Team Role: Driver
acdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond repute
Send a message via AIM to acdcfan259
My god those are ugly.
Unread 01-08-2008, 12:08
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Personally I am not a fan of almost any Toyota styling. My recommendation would be to wait for the Lexus version to come out. It will be black with tan "interior".
Unread 01-08-2008, 15:40
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
I am not a great programmer, but I have a little experience.
I hope you don't mind, but I have modified your code slightly to make it more readable (well, at least for me).
I found two places where it looks like some brackets may have been left out. This is where my lack of expertise shows it's ugly head. If I am correct, the code will not execute as desired if left this way. One of the places will prevent the "angle" to ever be set to "0" if it is in the window you defined. That being the case, the "flag" will never be set to "0" either. This looks like it may affect your stability around the balance point.
Below is my modified code. I added color to the sections that needed brackets (in my opinion).
Code:
#include<16f877a.h>
#DEVICE ADC=10
int BIN (float x)
if (x==0)
return(0);
if (x>0)
return (1);
if (x<0)
return(-1);
void main ()
int flag=0;
//sets up timer
//Setup the ADC
set_pwm1_duty(0);
set_pwm2_duty(0);
delay_ms(3000);
while(1)
dt=get_timer1();
set_timer1(0x0000);
old_angle=angle;
set_adc_channel(0);
delay_us(10);
ax_adc=read_adc();
delay_us(60);
set_adc_channel(1);
delay_us(10);
else
else
angle=0;
else
angle=angle;
flag = BIN(angle);
new_angle = angle;
if(motor>178)
motor=178;
motor=-178;
else
//flag=1 => forward
if (flag==1)
//delay_us(10);
// delay_us(50);
//Reverse
else if (flag==-1)
//delay_us(10);
//delay_us(50);
else
lmotor=rmotor=0;
old_angle = angle;
delay_ms(20);
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 01-08-2008, 17:01
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
The brackets can actually be left out in this case, since in C an if-then structure is formatted as "if-conditional statement;" where "statement" is the one line executed if the conditional is true. However, since one usually needs more than one statement per conditional, the brackets allow you to put multiple statements into a block, which C thent treats as one statement for the purpose of the conditional.
That having been said, the addition of the brackets certainly makes it more readable and, if you ever have to add another statement into the block, it makes it much easier to do it quickly.
I cut myself shaving with Occam's razor.
Unread 01-08-2008, 17:19
billbo911's Avatar
This is the best thing about CD. One can admit their shortcomings and not be ridiculed for them. Instead, they receive an education.
Thanks for helping me (us) out on this!
Gohan22, ignore what I said.
  #15   Spotlight this post!
Unread 01-08-2008, 18:35
no its all good... that was actually new to me as well. I always thought that you needed the brackets. So anyone have any ideas of how to remove the vibrations from the scooter?
Building self balancing scooter- troubles with Integrating Gyro gohan22 Sensors 8 22-01-2009 23:06
Motor specs for self-balancing scooter dunkonu Motors 1 23-02-2008 12:05
Team 862 - Self Balancing Scooter jakep Robot Showcase 15 10-10-2006 21:01
FIRST-made Scooter VEN Chit-Chat 7 25-01-2006 15:36
pic: super scooter CD47-Bot Extra Discussion 12 05-08-2004 18:40
