Go to Post YES... ITS VERY VERY VERY VERY VERY VERY VERY BAD for my health, cause I like it way too much that at times I will forget to sleep. I love FIRST. :] - Arefin Bari [more]
Unread 11-08-2008, 15:36
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
Re: Securing gears on shafts
I'm sure someone has probably mentioned this and I missed, but that's ok I'll jump on this dog pile nonetheless....
A very reliable method that has worked in the past for me is using pins in the hubs....buy a standard sized steel pin (one size should work for many, many applications so this is a one time investment you can use again and again)
this can be done pretty easily with a vice and a standard table top drill press
So for example if I had a quarter inch pin I would buy a bit two steps down on your handy ansi size charts (in this case a C drill bit will work; .2420) drill the .2420 hole through the hub (perpendicular to the shaft, not through the face of the gear) and then drill through the shaft where you want the hub to sit
repeat the same process with these new drilled holes, but this time use a reamer that is only one step down from 1/4" (in this case a D reamer; .2460)
now slide your gear on your shaft start the pin in the hole on the hub and use a press (or if you dont have access to a press, a hammer will work, notice I said it would work but may not be ideal) to force the pin down through the hub and shaft, stop once you are all the way through the hub
this is a very good connection; if it something you will be changing often I wouldn't try it, but if you just want something that you want to be permanent and you don't want to even think about it breakin/coming loose
Oh and if something somehow shears (has yet to happen to me)....knock/drill back out the pin and just go to a larger pin size using the same method.....
gl
Unread 11-08-2008, 19:43
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Unfortunately, no hub in this case...
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
