Go to Post If the fan club goes away, or isn't always right in your face doing things the public sees, does that mean the reason for the fan club is gone? Nope. - Elgin Clock [more]
Unread 01-08-2008, 22:39
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Securing gears on shafts
Hello,
I was wondering if there were any ways to secure gears on shafts. I don't mean along the axis of rotation (that is easily solved by hex/keyway broaching gears or carefully welding). How would I keep a gear from sliding along a hex shaft if it was already broached to the correct size?
I have thought of tack welding, roll pins, spacers, and set screws in the place of roll pins.
I ruled out tack welding because it would be nice to be able to reuse the gears in a case of emergency, and I don't have the clearance in some parts for spacers.
I am probably going to resort to using set screws but I was wondering how some other teams secured their gears on shafts.
thank you, Vivek
"we don't build robots, we build people"
Unread 01-08-2008, 22:58
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Securing gears on shafts
Get gears with hubs. Drill a hole in the hub, tap it, and setscrew the gear to the shaft. It's probably a good idea to locktite the setscrew, just to be sure
Unread 01-08-2008, 23:12
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
unfortunately, I already got gears without hubs. I was wondering if there was anything like an e-clip for hex shaft?
thanks, Vivek
Unread 01-08-2008, 23:17
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
You could still machine a snap ring or e-clip/retaining ring groove on a hex shaft.
You could also try one of those push-on style self locking rings.
Lastly, they sell clamping collars with hex bores which may work.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 01-08-2008, 23:21
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
seconded on the collars. A round bore collar would also probably work okay.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 01-08-2008, 23:42
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
We use McMaster.com, go to their site and type in "aluminum collar". Click on About aluminum collar and there you go, the best method, we used 20 aluminum collars this year on our robot for multiple purposes.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 02-08-2008, 00:04
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
eclips would probably be a good solution. I haven't used them before. I still don't think I have enough clearance for the locking collars.
What do you think about gorilla glue? It is a gearbox so there should be no side load on the gears. Wouldn't a few dabs of gorilla glue work?
thanks, Vivek
Unread 02-08-2008, 00:11
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
For most purposes, a decent Epoxy will hold better than gorilla glue. In either case, if you choose to do so, make sure all parts are completely grease-free before application.
you could also use a small roll pin, if you have the machining capabilities to do so (which you probably do, if you are custom making a gearbox) as the Tough box did this year.
How much clearance do you have?
If there is not enough clearance between the gears for shaft collars, but more than 1/16 of an inch, small spacers (cut from tube stock, or from the IGUS bag) have worked well for us in the past, with either shaft collars where there is more clearance, or the gearbox walls to hold all the parts together.
Unread 02-08-2008, 00:52
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
By clearance I mean a gear from another shaft in the gearbox comes too close to the hex shaft which would need a collar/spacer. Sorry if that doesn't make sense. It makes sense to me but I have the gearbox memorized.
After talking to Chris lyddiatt from 1114, I've decided to go with roll pins. Although, more ideas would be appreciated if teams have found any creative ways to secure gears.
thanks, Vivek
Unread 02-08-2008, 00:54
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Oh, I thought you meant that two gears on the same shaft needed to be very close together.
Roll pins should work fine.
Unread 02-08-2008, 03:50
thatmorman's Avatar
thatmorman thatmorman is offline
David
AKA: David
FRC #1510 (Wildcats)
Team Role: Leadership
Rookie Year: 2007
thatmorman will become famous soon enough
Send a message via AIM to thatmorman Send a message via MSN to thatmorman
set collars work very nice, but they are heavy. one solution that is a little more cheap is zip ties. it doesn't necessarily look nice, and its not the most affective, but it works in most situations...
David Cobbley
Captain & Mechanical Leader
Team 1510
I <3 inventor & anyone in FIRST
Unread 08-08-2008, 10:52
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Rookie Year: 1999
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
If you are going to Loctite it (which I recommend) try to use the blue variety. It'll hold, but you can get it off later in the heat of battle without working too hard. The red will just cause unnecessary frustration.
Speaking of being "in the heat of battle", I'm a huge fan of pinning gears, hubs, etc to shafts. If you're trying to install one and someone says "you have 30 seconds to be on the field", a drill bit and a quick 'snap' can work wonders, if anything to get you through one more match.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 08-08-2008, 11:12
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
"LOCTITE THREADLOCKER 222 LOW STRENGTH PURPLE, 6 ML. TUBE (38653)
E-mail this product to a friend
Low strength threadlocker. Designed for precision metal fasteners under 19mm. Protects threads from rust and corrosion. Removable with hand tools.
Applications: Set screws, adjustment screws, calibration screws, meters, gauges. "
Nobody ever seems to use Purple. Not sure why. Grant Imahara recommends it in his Battlebots book Kicking Bot.
Unread 08-08-2008, 11:47
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
Speaking of that, get a bunch of 3/32" bits. they're only 52 cents here: http://www.buydrillbits.com/products...?c=JL-USA-FRAC
Just invest in 40 of them. they're only twice the price of spring pins.
I am slightly kidding but it does seem like a good idea in a hurry
It would probably be better to use a spring pin.
-Vivek
  #15   Spotlight this post!
Unread 09-08-2008, 13:37
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
You can get a 10-pack of 3/32" bits at Harbor Freight for $1.49, not that there very good ones. http://www.harborfreight.com/cpi/cta...emnumber=93077
One think I find useful around the shop is to have some drill rod in various sizes. In smaller sizes, it is very inexpensive. You can get a 3 ft. length of 3/32" drill rod for about a buck. Larger sizes can be used for axles, etc.
http://www.use-enco.com/CGI/INPDFF?PMPAGE=789&PMCTLG=00
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
