Compact rio not being able to use C
I may sound like an idiot here but awhile back a person from NI came to my team and told us that the compact RIO can't use C programing. I was not at that meeting and want to know for sure if this is true. Can you guys give me and other sources than FIRST and NI, because they have so far been non-conclusive. It would be great if someone had a link to a place where this was announced, so i can show my team.
Thank You. |
Re: Compact rio not being able to use C
I suggest you look around. It has been clearly stated a number of times that the compactrio WILL be supporting C and that WPI will be handling the C library coding to keep it on equal footing with what NI releases for Labview.
Thank you i thought so i just need a way to prove it to my team because this guy was a pretty smooth talker and has them all convinced.
this is good news for me thanks for the fast reply. |
National Instruments has not yet released anything for C with the Compact Rio to the general public. We are one of the guinea pigs.
It's very likely the person you spoke to is not aware of the development of the FIRST controller and the C interface. Here is the NI press release, which mentions C programming: http://digital.ni.com/worldwide/bwco...25742B00737DF5 |
Does anyone know if we can use EasyC with the new controller? Forgive me if that's a stupid question, I'm no programmer. The last thing I programmed was an Apple 2 using Basic.
No, currently there is no plan for EasyC or any program like it to be available for the new controller. However, if you're used to using EasyC, using LabVIEW might not be too difficult since LabVIEW is a graphical programming environment, where you place blocks on a block diagram and wire them together.
I haven't heard anything about EasyC being adapted to be used with the new controller, but I expect someone to release a comparable IDE for the new system.
Thanks.
#10
Intelitek hasn't given an official statement regarding easyC, (imho) it sounds like they are either working on it, or they are not. So I wouldn't rule it out (just quite yet.)
My $.02 Jacob |
#11
From my understanding, the cRIO would be programmable in C++. Is this still the case? I remember quite a buzz about finally being able to use C++ as opposed to C.
#12
I heard that to, or was that dealing with using C++ inside of labview.
#13
From what I remember from the mentor presentation in Atlanta, the compiler that will be used is GCC (with an IDE provided by Wind River). So since C++ is mostly a superset of C, if the base code is provided in C it will compile in C++ as well. (I suppose this implies that you can also write a module or two in Fortran, Objective C, Ada, etc. if you really want.)
#14
I realize the base code will compile in C++ if you can compile in C. However, I'm looking forward to using the features presented in C++ that aren't in C such as being able to use Object-Oriented Programming techniques and templates. My question is: will we be able to write/compile code in C++? I thought that this was the case.
#15
I haven't done much work with Compact RIO, but can you not use Code Interface Nodes with them?
| First CROSSING not being scored? | jgannon | Rules/Strategy | 22 | 09-03-2008 11:08 |
| CMUCam Forum messages are not being poseted as recent activity in the portal | Bob22341 | CD Forum Support | 3 | 31-01-2007 22:34 |
| Ethics 101: To re-use or not to re-use? | aaeamdar | General Forum | 87 | 07-12-2006 19:10 |
| Anyone concerned about the possibility of not being allowed to go to Nationals? | skrussel | Championship Event | 41 | 03-04-2003 11:35 |
| EDU RC not being recognized... | Caleb Fulton | Programming | 5 | 24-03-2003 09:29 |
