Go to Post For years, Dave Lavery couldn't fart without people trying to interpret it as a game hint. - Taylor [more]
Unread 21-08-2008, 21:16
UndergroundVoid's Avatar
UndergroundVoid UndergroundVoid is offline
System Ready...
AKA: Lynx
UndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the rough
Send a message via AIM to UndergroundVoid
Treads, Tracks, Tank system Talk/Help
The Background:
Alright, I would like to say to start off I love treads/ tracks/tank drive and feel the need to please the tank gods. My team has had a tank drive system for one year and support after that year for tank type drive systems have died and have be replaced with others systems aka wheels, omnis, mecanum, etc. The robot equipped with the tank drive system was for a while my roommate as i had made repairs but found out why then bot had so much issues like fractured lex sand framework and really bad gearboxes but yet it holds true to my heart. I'm revamping its design which is near completion but has some questions that need answering before it can be completed and also it may have more questions that i may have not thought of.
The Question:
1. What gear ratios should i have for the tank tank system (motor to gearbox output)?
Note: I'm not stupid i know there is a series of equations to find the right ratio but I'm looking mainly for what others have done that might work for me.
2. How to solve the walking effect where i seen some robots with treads hobble as they turn and even become unbalanced that the driver has to stop?
I assume this is from the tracks not being held center because of certain belt track systems.
3. How to correctly tension the tank system, such as spring loaded or motor controller tension or to have the tracks at a fixed tension set by the frame?
General Talk:
I'm also looking for just a general what you may have done in this field of drive train and certain things you may have experienced that may help me and everyone have a better idea on how to produce tank systems to please the tank gods.
I refuse to go silently into the night by taking the easy way out.
The manual doesn't have all the answers since nobody can plan for everything.
Things can be more simple than you think.
Unread 22-08-2008, 01:14
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: Treads, Tracks, Tank system Talk/Help
997 has a very impressive tank drive, might want to ask them.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 22-08-2008, 01:22
as do the RoboWizards 522. Feel free to contact any of their active CD members.
Unread 22-08-2008, 08:14
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Some of the issues you are asking about are typical of tank tread systems. One that you have not mentioned is the bane of tank drive using treads or locked wheels, i.e.stalled motors.
When using treads on carpet, the side friction (during turns) with the carpet is so high that robot has to hop to break free from the carpet surface. Since the motor/transmission is usually capable of enough torque to overcome the friction, the robot hops when turning. However, during these moves the motors are at, or very near, stall. In a four motor drive using the CIMs, that is potentially over 400 amps. In the IFI control system, this causes the battery voltage to temporarily fall below the drop out voltage of 8 volts, and the controller goes into protect mode disabling all outputs and switching to the backup battery. (We don't have any data yet on what the new controllers might do under these conditions.) A wheeled robot in the same kind of drive could have a little less side friction but the problem remains and they also will hop to some extent in turns. Drivers can minimize the hopping by turning in conjunction with forward or backward motion. The AndyMark style wheels that have no side friction were developed for this reason. Everyone tries tank treads from time to time, but the tradeoffs are usually significant enough that teams go back to wheeled drive systems. Any game in which turning is required will have a minimum number of robots with treads. This year's game is a good example.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 22-08-2008, 08:56
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
I have no robot experience with tank treads, but most tractors used a single powersource into a differential with turning brakes. This is common on wheeled tractors too (they are often called plow brakes). Using the differential and side brakes essentially allows for torque vectoring and keeping from a stall condition. A couple of teams did this style of drive system this year to help with Car-style steering robots. This probably won't help with the side traction hopping, but it may help keep the current loads lower.
Unread 22-08-2008, 09:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I watched a couple of shows on Discovery (one was JYW where their task was to build a tank) and I believe actual tanks used to be built the same way.
An idea I played around in CAD a few months ago took the 6WD rocking-style drive train and converted the front four wheels into tank treads. The design put most of the weight in the back so the 'bot never really rocked forward onto the treads, however the tank treads would greatly improve the ability to climb ramps. Maybe it's worth exploring, maybe not...I didn't have time to fully CAD it out and consider the possibilities.
GitHub
Unread 22-08-2008, 10:25
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
You can greatly increase the mobility of the tread system if you decrease the surface contact.
Take team 522 for example. Year after year they produce a successful tread system.
http://www.chiefdelphi.com/media/photos/17294
Their surface contact basically creates a square profile on the ground and allows the robot to turn with more ease.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 22-08-2008, 11:58
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Thinking about tank treads and other drive configurations is probably a good idea. The past few years many teams have gone to 6 small wheel designs. For the most part the games have been played on flat surfaces. This has not always been true. What would your team do for a drive system if this years game required going up stairs or getting up on a platform?
Unread 22-08-2008, 14:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Pull yourself up to it from the floor
2001-2004: Team 100
2006-Present: Team 254
Unread 22-08-2008, 15:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I'd suggest triwheels.
But I'm just a programmer, so when it comes to mechanical design I don't get too vocal about my preferences.
Unread 22-08-2008, 17:40
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
... What would your team do for a drive system if this years game required going up stairs or getting up on a platform?
We did that once with a 2-wheel-drive setup. It all depends on the specifics.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 23-08-2008, 11:39
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Has there been a game yet that REQUIRED teams to climb obstacles? Seems a lot of the successful teams from 1999 and 2004 found clever ways to avoid climbing things.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 23-08-2008, 14:50
AndyB's Avatar
AKA: Andy Burchardt
There have been games with obstacles that needed to be climbed. But I understand what your saying.
But treads, WHEN DONE RIGHT, are a great option for maneuvering up and over obstacles such as steps, ramps, etc...
There is a reason why tanks use treads.
Unread 23-08-2008, 21:53
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Yes, the reason is that they are better at spreading the weight of an 80 ton battle tank when crossing mud.
I won't advise you how to do tank treads because I don't know how, but I will advise you to look to the military and their move away from treads. (run a search on Stryker) Tank treads are great for uneven and shifting terrains but for speed and maneuverability they are not the most effective.
Now, would it be cool to do a tank tread system that could climb a 70 degree incline as a demo? Oh you bet it would be. My best suggestion would be to look at the military tanks and how they work. An interesting thing to do might be to have a way of letting your treads lose friction as they are moving sideways (similar to omni wheels) Might be interesting to make work, dont know how useful it would be though.
Just my (programmer's) $.02
  #15   Spotlight this post!
Unread 22-08-2008, 14:45
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Rookie Year: 2000
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Your center of gravity has a very impact on this issue also. Assume you have a four cog setup (three similar to a six wheel drive setup and one tensioner) and your weight is either towards the front cog or the back cog you will run into this issue. However by finding the happy medium between center cog drop and your center of gravity as close to the center/low as possible many track systems level out on that center wheel as they reach. My understanding is that this is due to the tread actually sinking a little. This gives the robot a slightly larger footprint to balance on. Account for that and the length of the belt touching the carpet,its like turning a very short but wide wheel base. Another thing that drivers tend to do is not let the robot settle for a second before trying to turn this often throws off the center of gravity way over to the front/rear cogs. To settle the robot you don't necessarily have to stop the machine but just let up slightly to bring down the robots acceleration and allow the robot to tilt back on plane with the center cogs. However I do agree with Al in saying if it is not necessary for the game why implement it. Tread's are superb and often faster at vertical obstacles(stairs, bumps, etc.) but in a flat floor game it tends to be prohibitive.
Best of luck,
Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Tank Treads??? SLA Kit & Additional Hardware 2 16-01-2007 20:53
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Tank treads snowdragon General Forum 0 21-01-2004 16:57
Tank tracks vs. Wheels MBosompra Technical Discussion 28 16-01-2004 23:31
Where Can I Get Some Wheels Or Tank Tracks? Alex Cormier Kit & Additional Hardware 5 13-01-2003 22:58
