Capabilities of a Hall-Effect sensor
I am wondering if a Hall-Effect sensor could be use to sense how close a material is to it (using it much like a proximity probe). I'm talking about a range from 0-30 mils. The material being used is close to Inconel. Price is not an issue, so if you can find one, even if it's a couple thousand, please tell me. The only reason I'm asking here is because I know there are quite a few applications in robotics (such as gear tooth counting).
| Hall Effect Sensor Transmission Placement | robotoby35138 | Electrical | 1 | 06-02-2006 18:43 |
| The Hall Effect sensor wiring? | LaughingJack | Electrical | 11 | 21-02-2005 13:35 |
| Hall Effect Sensor Example Code | JJMax7 | Programming | 6 | 16-02-2005 02:38 |
| Hall effect sensor Filtering | magical hands | Programming | 5 | 13-02-2005 11:23 |
| Hall Effect Sensor. | Nixterrimus | Electrical | 77 | 29-01-2005 10:48 |
