Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Unread 27-08-2008, 08:56
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Capabilities of a Hall-Effect sensor
I am wondering if a Hall-Effect sensor could be use to sense how close a material is to it (using it much like a proximity probe). I'm talking about a range from 0-30 mils. The material being used is close to Inconel. Price is not an issue, so if you can find one, even if it's a couple thousand, please tell me. The only reason I'm asking here is because I know there are quite a few applications in robotics (such as gear tooth counting).
Hall Effect Sensor Transmission Placement robotoby35138 Electrical 1 06-02-2006 18:43
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Hall Effect Sensor Example Code JJMax7 Programming 6 16-02-2005 02:38
Hall effect sensor Filtering magical hands Programming 5 13-02-2005 11:23
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
