Go to Post Team 1114 does not design or build ROBOTS. They build AWESOME. - DonRotolo [more]
Unread 03-09-2008, 17:13
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Spacing needed between two #25 sprockets
This is fairly simple question. How much spacing would I need between two #25 sprockets for the chains not to interfere. If anyone could help that would be great. I notice that the infamous 254/968 transmission has two sprockets relatively close together and if someone knew specifically how close they are that would be awesome.
Mentor 2415
Unread 03-09-2008, 17:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Spacing needed between two #25 sprockets
A strand of #25 roller chain is a bit less than 5/16" wide across the length of the pins, so anything above 5/16" would work. I'd go with 3/8"
2001-2004: Team 100
2006-Present: Team 254
Unread 03-09-2008, 17:35
AKA: Sean
Just the person I wanted to respond. Thank you very much.
Mentor 2415
Unread 03-09-2008, 18:31
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
You might want to make it a little bigger for safety if you are not sure. I am not sure how much side ways slop you might have with the chain on the sprocket. Meaning the center of the teeth might not be the center of the chain if it can slide sideways just slightly. Also, you wouldnt want a master link or your link to snag against another chain if you didnt account for that.
Unread 03-09-2008, 18:55
DonRotolo's Avatar
Back to humble
FRC #0832
Be sure there is enough clearance to get one chain off by lifting it from the sprocket if there is a second chain on the other sprocket. Otherwise you will always have to feed one chain off, which can be a pain depending on the configuration.
Unread 03-09-2008, 21:35
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Perhaps some of the dimensions in this sprocket catalog would be useful. See page 77 - multiple strand sprockets. Note that I'm not sure if those are multiple individual strands or a composite single chain.
http://www.ustsubaki.com/pdf/sprocke...log_L10916.pdf
Some actual chain dimensions:
http://www.ustsubaki.com/pdf/gen_catalog/gen_a6-a12.pdf
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 03-09-2008, 23:20
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
to reiterate...
make sure you account for a master link on each sprocket possibly hitting each otherr
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 04-09-2008, 18:39
Dick Linn's Avatar
no team (Synergy)
The Tsubaki chain catalog link above lists their dimensions for distance from centerline L1 and L2, which are different. L2 is the master link side, which protrudes further. That's not to say that other chain brands won't differ, but it's probably representative. It may be ANSI-spec chain. The devil is in the details
Oh, don't forget that there will be some clearance between sprocket and chain and that the whole chain can slide laterally (axially) a wee bit. If you place the centerlines of the two sprockets less than 7/16" apart, be watchful. 3/8" might do OK... depends on which side the master link clip is on.
Hey all you math-wiz types: figure what size actual length spacer is needed on the shaft between the two sprockets to provide the correct distance. I'm too tired tonight from trying to figure out how to fix up an automated truck weighing system and a kiln position/board moisture tracking system for a local lumber company. SOmebody did some JAVA programming to tie things together and there are a few glitches...hmmm.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 04-09-2008, 19:25
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Most of the time when you have two chain runs driven off paired sprockets (at least from what I've seen) they are going to the same size sprocket on the other end. In which case, the chains will always stay relative to each other, and you can just space the master links apart and never have to worry about them hitting.
Unread 04-09-2008, 20:41
AKA: Sean
That is kinda the idea that I had. It will be same sized sprockets side by side so they should move relative to each other. This question is in reference to the west coast style drivetrain I have posted
Mentor 2415
Mounting two output sprockets on andyMark :confused: EduardoVemny Motors 5 10-01-2008 21:37
Camera tracking between two lights Ankush Dhar Programming 2 12-02-2007 23:44
Needed: Two people at Palmetto Billfred Regional Competitions 5 21-03-2005 15:04
Polar direction between two cylinders reilly Pneumatics 4 18-02-2005 11:38
