"Save as" Image Quality
Are there settings to optimize the image quality when doing a "save as" in Inventor?
I'd like to quickly generate some .jpg files of my models. I was hoping to use the "save as" feature with a presentation background. Unfortunately the quality is just so-so. Anyone have a quick tip?? |
Re: "Save as" Image Quality
If you are just doing screen shots go into your application options under tools and go to display. Make sure to turn off edges under the active title. Also you can temporarly change your background from blue to white for easy photoshop manipulation.
The best way would be to use inventor studio with the default settings and do a quick render with the resolution of your choice. the first image is a screenshot with edges turned off. The second is a quick render with the default settings. Last edited by Greg Needel : 01-10-2008 at 11:03. |
| "Save as Draft"? | Jaine Perotti | CD Forum Support | 5 | 30-03-2005 19:17 |
| What is a "Quality" post? | Ken Leung | General Forum | 29 | 25-02-2005 00:59 |
| Image Discuss: 1132's 2003 "The Claw" | CD47-Bot | Robot Showcase | 7 | 26-02-2003 16:34 |
| Image Discuss: Team 481 "Spike" | CD47-Bot | Robot Showcase | 7 | 26-02-2003 01:02 |
