Go to Post ...UFH nominations are like jello, there is always room for one more. - Barry Bonzack [more]
Unread 01-10-2008, 12:15
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Best hand tool to use to cut sheet metal (aluminum diamond plate)?
I'm sure this has been asked before, but I did search and didn't come up with anything yet.
Anyways, I have some sheets of aluminum diamond plate (slightly used) that I need to cut that are about 1/4' thick.
Some of my cuts will be just to trim some off of the sides the whole way down the ~4x8 sheet, but other cuts will be angled so the piece looks like a rather large triangle shape.
I can lay out a wooden jig to follow (instead of just a line with a sharpie drawn on it for a bit more accuracy) but my question is, what kind of tool & blade do I need?
I want to buy a circular saw anyways, but if I used that what kind of blade would I need?
We've cut metal before on a table saw for the team but I don't have access to that until build season, & I want to get this project finished over the fall/winter time.
Any help would be appreciated. Thanks!
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
ALuminum jig plate - cheap surplus Dick Linn Technical Discussion 0 19-12-2007 12:40
Rules concerning manipulating circular diamond plate on a spider leg for stability Drew Rules/Strategy 3 09-01-2007 14:51
How do you tell whether your sensor is detecting a crate or the diamond plate? Greg Ross Technical Discussion 4 13-01-2003 19:02
Aluminum Plate archiver 2001 1 24-06-2002 00:03
1/4" Aluminum Plate Brian_Lim Rules/Strategy 3 15-01-2002 18:32
