Go to Post What do you do after making a design public? Improve it! What do you do when you give your opponents a weapon? Come up with a better one or a way to beat it! What is Wildstang going to do, you ask? Make their drivetrains better! - EricH [more]
Unread 07-10-2008, 16:08
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
Rookie Year: 2007
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Team 39, 2008 LabVIEW Beta Code
http://hhsrobotics.org/forums/viewtopic.php?f=4&t=3
We just released the first revision.
More coming soon.
rev0.1--
this revision only includes the teleoperated mode. it has been tested on the robot.
Enjoy!
-Borna Emami
Team 0x27
Unread 07-10-2008, 16:25
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Re: Team 39, 2008 LabVIEW Beta Code
Could you post images of the VIs? My team does not have access to LabView yet.
Unread 07-10-2008, 16:33
BornaE's Avatar
Rookie Year: 2007
Sure, I was going to do that.
I will post the pics sometime tonight
-Borna Emami
Team 0x27
Unread 07-10-2008, 19:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
For the health of your board there, you might want to set permissions so people don't have to register to download this file. Else you'll be getting a rather lot of one-time registrations.
EDIT:
Second point, pictures are going to be slightly more meaningful, because all of us out here are lacking the dozens of WPI VIs needed to make sense of your code. Nevertheless, I'd like to suggest that you look into "Enumeration Constants" for passing your states around, instead of variable length strings. Eric will probably swoop in here and declare that we have so much processing power that it doesn't matter... But I think some things just shouldn't be done. Plus, enumeration constants will make your state-flow code immune to typos in your states.
Unread 07-10-2008, 22:10
BornaE's Avatar
Rookie Year: 2007
Oops, I thought phpbb did that by default. I will change it.
That code was cramped in one day. I have cleaned it up but want to test it before posting.
Thanks for the suggestions.
-Borna Emami
Team 0x27
Unread 07-10-2008, 22:33
BornaE's Avatar
Rookie Year: 2007
HTML version just posted.
-Borna Emami
Team 0x27
Unread 08-10-2008, 09:01
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
The cRIO's PowerPC/FPGA combo is obviously far more processing-capable than the old IFI setup. However, that's no reason to write sloppy and inefficient code.
With a bit of LabVIEW experience, you'll learn to appreciate the value of the enumerated type (as in C/C++). I would strongly encourage every LabVIEW programmer to use this datatype wherever possible. It's always good practice to remove "magic numbers" from your code.
Russ
Unread 08-10-2008, 10:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I looked through the code - and I have to wonder if it isn't time for FIRST to release some explanations of how the system is going to function.
I looked at it and was completely confused as to how it was supposed to work - and I'm betting other people are going to have the exact same reaction.
Unread 08-10-2008, 10:50
Rookie Year: 1998
Tom,
I think the code looks.... reasonably straight forward. But then, I'm a bit used to deciphering Labview code. It looks like most every function is going to be run through those XYZ-Open,Something,Close function blocks. Open XYZ on Port B at Slot A, either when the robot is turned on or when initializing into a mode. Do something to it. Close it when your robot turns off, stops needing it, or stops running the Labview code. I imagine the latter is important to not forget, since it could possibly confound things if you don't close these ports when you stop the code to make a programming change.
I'm a little concerned that I don't see any DaqMX tasks in this code. I realize it's slightly advanced stuff, but it's important slightly advanced stuff. You can set up hardware timed data sampling tasks that run at much higher frequencies than your background processing tasks, as well as setting up custom scales and all sorts of other things. Hopefully it's just that beta teams haven't gotten around to looking at that sort of thing yet, as opposed to it not being an option.
Borna,
A few followup questions from an interested bystander:
1. I assume the pink wires in and out of the various modules (DigMd, AnlgMd) are carrying module configuration info. Are the shift registers you have on these module configuration lines actually necessary? Could they instead just be simple tunnels, as with the Joystick in your main loop?
2. Is 25 Hz just a random loop timing decision on your part, or is it the recommended max loop rate?
3. The Victor/PWM modules seem to have some sort of deadband and transform setup. Does that configuration happen in a separate module?
Unread 08-10-2008, 12:32
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
That is one point on which several beta teams are confused. It really depends on whether the references carry state information (best I can tell, some do and some don't). There have been a lot of ideas thrown around on how to improve things, both through examples and added documentation.
It is the rate at which the driver station sends data. That should be raised soon. I have not seen any recommendations as to a maximum.
There are 4 PWM type VI Libraries, a raw PWM, a Victor, a Jaguar, and a servo. The Victor, Jaguar, and Servo have different types of deadband and scaling control. You can use the raw PWM, if you want to implement your own methods for scaling and or deadband elimination.
For example, The deadband control for Victor is a boolean value, whether to scale the inputs to eliminate the victor deadzone and center on 127 (rather then 132) or not.
Unread 08-10-2008, 12:52
BornaE's Avatar
Rookie Year: 2007
Tom,
The pink Wires pass the device refrence information, but there are some subVIs that can change the parameteres in that cluster.
too keep the new data for the next loops, shiftregisters are needed.
but in our case as of now, tunnels would work the same.
For our code as of now, we dont need to sample the inputs more that 25hz since thats the only time they are needed. once we get to gyros or accelerometers, sampling fater would come in handy.
I promise the next revision looks much better.
-Borna Emami
Team 0x27
Unread 08-10-2008, 13:48
Rookie Year: 1998
It is the rate at which the driver station sends data. That should be raised to 40hz soon (same as IFI). I have not seen any recommendations as to a maximum.
Ah. Good to know, then. One more followup while I'm on my lunch break. Is it possible to run separate loops at higher rates for improving PID control? For example, with the IFI RC, you could set up the "fast loop" to update some of the PWM outputs at whatever speed you liked. Given that the Victors can theoretically handle update rates of 120Hz, I'd dislike having to throttle them to whatever the update rate of the DS is.
Posting LabView Code Easily? Greg Marra NI LabVIEW 17 25-11-2009 16:49
LabView FRC Toolkit code level issue KHall National Instruments LabVIEW and Data Acquisition 2 11-06-2008 10:40
[TBA] Match Archives 2008 (beta) Greg Marra The Blue Alliance 16 07-10-2007 14:39
Configuring Labview code to easyC team877 LabView and Data Acquisition 6 16-01-2007 09:21
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
