E- Stop and The New FRC Control System
Please, some one tell me I'm wrong, that I'm just paranoid, but I watched the NI joy stick control in 10 minutes video several times and I did not see a disable or E-Stop switch hooked to the operator interface. The NI guy had no problem writing a VI that apparently ignored the lack of a kill switch. Trying to click on the stop execution tab with a mouse while a drive chain is chewing up a student is not acceptable. How is a total compact rio shut down handled? I have not seen any thing yet that leads me to believe that this issue is well handled. Please NI and beta teams tell me I have nothing to worry about.
Also note that there does not appear to be any fuse between the battery and the victors in the video. Sloppy. |
Re: E- Stop and The New FRC Control System
This issue is handled through the competition port on the DS(Drivers Station) There are 2 commands that disable the robot. the Disable command and the E-stop. when the cRio receives the disable command, the outputs are temporarily disabled, and can be re-enabled again. When the cRio receives the E-Stop command, all the outputs are disabled until the cRio is rebooted. |
Yes, I Know there are provisions for a diable and e-stop. How ever it appears that these are easily by passed and are not intrinsic to the operation.
The coding doesn't require the e-stop to be connected to operate. the E-Stop will still be on the driver station as a means to diable the robot. -Mike |
What specifically in the video made you think it was easily bypassed? Last edited by Joe Ross : 08-10-2008 at 16:31. Reason: switch is required |
Just to ask, is there also an "autonomous" pin to hook
to a switch as in the competition port on the prior control system? Eugene |
There's an autonomous/teleop switch on the OI. You have to move a jumper around to run auton at this point in time.
In the video, for a spit second it appears that the OI competition port is bare. Nothing plugged in and the system is functioning. Shouldn't the system be disabled if nothing is in the port? The reason I'm especially concerned with the disable is that last week we started up the 2008 robot and it became instantly apparent just how important a functioning easily engaged disable button is.
So, if the new DS always disables the robot without a (preferably normally closed) switch connected to the competition port, then all is well with the functioning of the new system. It can obviously still be jumpered around with a soldering iron, etc., but it generally makes it much more difficult to kill yourself. |
#12
This does mean, however, that a team always has to have their switch on hand in order to enable the robot. |
#13
The thing that may cause confusion was the disabling of the user watchdog.
The system has two watchdogs, the system or intrinsic -- controlled by the driver station and DS switches, and the user watchdog -- optional and controlled by the cRIO running the user's code. If the intrinsic watchdog loses communications or is told to disable or e-stop, the FPGA shuts down I/O. Period. The user watchdog is ANDed with the intrinsic can request a disable as well. In the movie, the watchdog was simply disabled and wasn't used. Another usage would be to leave it enabled, and stroke the watchdog in a loop that verified conditions of the robot or joystick. It can be used to ensure that a core loop is executing every cycle and isn't hung or crashed. It can be used to implement a robot enable button on the joystick during early development. Greg McKaskle |
| OpenCV and New Control System | manderson5192 | Programming | 11 | 04-01-2009 16:11 |
| FRC control system to show up as default in the portal | BornaE | General Forum | 0 | 25-09-2008 17:00 |
| new FRC control system? | Jwxie | Programming | 2 | 30-06-2008 20:34 |
| New Innovation FIRST control system and the dashboard | archiver | 2000 | 0 | 23-06-2002 22:15 |
| UNFAIR ADVANTAGE for CDI and new control system | archiver | 2000 | 6 | 23-06-2002 22:13 |
