Go to Post The Tekin's used to constantly suffer from spontaneous combustion, it was extremely frustrating how often they would go. - Kingofl337 [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 21-10-2008, 20:19
KillerBeeVEX33's Avatar
KillerBeeVEX33 KillerBeeVEX33 is offline
None #0033 (Killer Bees)
KillerBeeVEX33 is an unknown quantity at this point
[OCCRA]: VEX score area clarification
I was wondering if the bottom of the score area for VEX bots will be flat and flush with the ground, or if there will be a small PVC pipe or something similar that makes it so even for a normal score (aside from the Field Goal), the ball must be lifted off the ground or if it can be slid right in.
I was just hoping I could get some clarification that way I can tweak the design if needed, since right now I am under the impression that the goal area has no lower "lip" to cross.
Quick sketch of idea of how it might look:
|=========| <-bar
| nothing here. |
|_____________|___ <- floor
Is this a correct assumption or is there a bar at the floor? Please clarify if possible. (Sorry if it was confusing)
[OCCRA]: 2008 OCCRA VEX Carpet Playing Field - Home Depot marccenter OCCRA Programming 1 06-11-2008 09:57
[OCCRA]: OCCRA Competitions require VEX tether cable marccenter OCCRA Programming 1 24-10-2008 09:57
[OCCRA]: Rule Clarification Viking(redneck) OCCRA 3 24-11-2004 09:41
