3dsMax on a Mac
I looked, and the last postings I found were from 2006.
My team is a mac school, and has two gorgeous labs of Macs. They have boot camp, and installed 3dsmax. However, when they reboot into OSX and then back into Windows, the software looses its authentication. I only got a fuzzy brief today from the lead teacher, not the animation teacher, but thought I would see if anyone else has had success or troubles when running with bootcamp. Thanks! Wetzel |
Re: 3dsMax on a Mac
Boot Camp should handle that well, or pick up a copy of VMWare Fusion. It works just as good as Parallels but handles video hardware acceleration better.
Re: 3dsMax on a Mac
Word of warning, if you try to use both Boot Camp AND Parallels 3ds max (and windows) may throw a fit.
I ran into the same problem with my mac about a year ago, if I recall correctly I just re validated 3ds and it worked from then on. I can also attest to the power of Parallels, I rendered 3/4 of the 397 animation on my mac via Parallels and it was reasonably quick. |
Re: 3dsMax on a Mac
Better question: Autodesk owns Maya in addition to 3D Studio Max. Maya is cross platform between Windows, Mac OSX, and Linux.
Why not allow either 3DS Max and/or Maya for the Autodesk-sponsored competition? |
Re: 3dsMax on a Mac
Re: 3dsMax on a Mac
My school has a new mac lab just installed this year that is for nothing but Maya, and one thing that I have found from it is that it is extremely powerful compared to 3Ds Max. Also it's very very complicated to learn according to the teacher.
Re: 3dsMax on a Mac
Back to the topic at hand, a quick google search revealed several threads on Apple and Autodesk forums saying that this is an issue. http://discussions.apple.com/thread....2968&tstart=60 http://usa.autodesk.com/adsk/servlet...linkID=9240818 is the hot fix that is suggested in the thread. I cannot recall if this is what I originally set up 3ds with (This was close to a year ago) My suggestion, try that. If it doesnt help run a couple google searches (3ds max and boot camp licensing issues) There are dozens of forums with potential solutions. Hope this helps. EDIT: Reasoning, Mac's have Sata controllers in them if I recall, (Least my MBP does) the hot fix I linked to is due to a problem with Autodesk's licensing and the Sata controllers, this does not appear to be a boot camp issue. Last edited by Andrew Schreiber : 23-10-2008 at 10:45. |
Re: 3dsMax on a Mac
I've used Maya before, and...well...it's an experience. Just trying to navigate through the hundreds of menus available at the click of a button is pretty darn confusing. I much prefer the 3DSMAX layout.
There are, however, some things Maya does better than Max. |
Re: 3dsMax on a Mac
When Autodesk bought Maya we thought they might allow it to be used in the Autodesk Visualization Award.
But so far, no; only 3ds Max. We'll see what happens when they post the 2009 rules. However if you already know one 3d program you can learn another pretty quickly... IF you keep an open mind. |
#10
Re: Inventor on a Mac
Has anyone dealt with using Inventor on a Mac? Do you have the same authentication issues? Are there other problems?
#11
Re: 3dsMax on a Mac
That would be cool if they allowed using Blender too. http://www.blender.org/ It has a steep learning curve (at least for me), but the people who can use it, use it well.
as for the mac question: I have no idea why it does that. Theoretically it should be fine and not complain. But, you could try Virtualbox instead. http://www.virtualbox.org/ |
| 3DSMAX Question | Raven_Writer | 3D Animation and Competition | 1 | 22-05-2004 15:27 |
| 3dsmax r5/r6 compatibility? | anishthakkar | 3D Animation and Competition | 2 | 05-01-2004 16:06 |
| Learning 3dSmax!! | Brian Wolz | 3D Animation and Competition | 5 | 08-01-2003 22:48 |
| lighting in 3DSMax | Falcon234 | 3D Animation and Competition | 2 | 10-02-2002 10:27 |
| 3dsmax 4.2 | the hardware | NaiLZ | 3D Animation and Competition | 13 | 11-01-2002 23:44 |
