Go to Post The only constant in FRC is change. Learning to adapt to change in competition is the best way to prepare for change in real life. - Jessica Boucher [more]
Unread 23-10-2008, 08:49
Steve Ketron's Avatar
Steve Ketron Steve Ketron is offline
FRC #1528 (MTR (Monroe Trojan Robotics), formerly iPirates)
Team Role: Teacher
Steve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to all
How to Flash A Controllers Memory
The programmers for my team are trying to flash the memory from an older controller(2005). They have been researching for ways to perform it but have not been successful. Can somebody give them references/sites or procedures on how to perform this task?
Unread 23-10-2008, 09:03
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: How to Flash A Controllers Memory
For the 2005 controller, easyC didn't exist, so your only finagle-free option is to use MPLAB. MPLAB itself and the C-Bot compiler must be gotten from a Kit of Parts disc; the most recent one should work fine. IFI Loader can be downloaded from the IFI Robotics Robot Controller page towards the bottom of the page.
In 2005, the PIC processor was of a different model than the more modern RCs. If you are coding in MPLAB, you probably started with the default code that IFI released. To use a modern default code with the old processor, follow the directions in the "Using_a_2005_FRC.txt" file in the root of the default code. For reference, I have included it below.
If you need more help, post back and let us know exactly where you are having problems--what error messages you get, indicator lights, etc. so that we can further assist you.
Using_a_2005_FRC.txt contents:
To compile this project to work with your 2005 FRC (18F8520) system do the following:
1. Select the correct device from the MPLAB IDE.
Configure->Select Device->PIC18F8520
2. Replace the library file with the appropriate one.
Remove the FRC_Library_8722.lib file and replace it with FRC_Library_8520.lib
or
Remove the FRC_alltimers_8722.lib file and replace it with FRC_alltimers_8520.lib
3. Remove the 18f8722.lkr file and replace it with the 18f8520.lkr file
4. Rebuild your project and download the HEX file to your controller.
Aren't signatures a bit outdated?
How much memory is there really? PhilBot Programming 13 05-02-2007 14:42
How would I interface a flash drive to the RC? JBotAlan Technical Discussion 42 31-01-2007 15:24
program memory Chris Bright Programming 1 25-01-2005 08:54
Linking two controllers together - the how? part DanL Programming 12 15-10-2003 22:17
refresh my memory archiver 2000 2 23-06-2002 22:40
