Go to Post Only a few more days till i get to see her again! This is sad you would think I was talking about a chick... no wonder my gf gets jealous. XD - sportzkrazzy [more]
Unread 25-10-2008, 01:22
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
numeric AND
I've seen the AND function used with numeric datatypes, and I really don't understand:
What the heck does it mean like that? Does it convert the integers into boolean arrays, perform the function as if on an array, and then convert them back?
Thanks!
-- Marshal Horn
Unread 25-10-2008, 01:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: numeric AND
Thanks!
I believe you have the right idea.
All processors store numbers as groups of bits. Performing an AND on numeric datatypes performs the AND operation on these sets of bits. The way the processor sees it no conversion is necessary, the data is already right there in the correct format to do a logical AND bit by bit.
This is often useful to grab parts of a number, usually the most or least significant bits.
Unread 25-10-2008, 01:37
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: numeric AND
Be careful about which AND you're talking about though, because there are two distinct types of AND.
Logical AND - "&&": This is the boolean type of AND that you're probably used to seeing. It can be used with numeric types as inputs, but generally translates numeric zeros to FALSE, and non-zero values to TRUE. It will generally output 0 for false, and 1 for true.
Bitwise AND - "&": This will take two numeric inputs, then perform a logical and for each bit in both inputs. For instance if you took two 8-bit binary numbers 11111111 & 00001111 = 00001111. Bitwise ANDs are commonly used for "bitmasking," which is when you only want to take few bits from a number and strip the rest away (make them 0).
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 25-10-2008, 11:10
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: numeric AND
Ah, okay. That would also explain why they're using hexadecimal on one side. Thank you!
-- Marshal Horn
Unread 27-10-2008, 14:48
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: numeric AND
In all my years of LabVIEW experience, I don't think that I've ever tried to AND a pair of integers but I just tried it and d*&n if LabVIEW and polymorphism don't just work hand-in-hand. I typically use byte-to-boolean array (or similar) for bitwise manipulations of integers but I'm definitely going to exploit fixed point boolean "arithmetic" more often.
Thanks!
Russ
Bill of Materials, do it and do it well, and bring it to your event sanddrag Rules/Strategy 3 24-03-2006 21:09
Thank you 1359 and 1569 and Congrats 492, 1595, 604 SilverStar Thanks and/or Congrats 0 13-03-2005 23:21
pic: Stars and Stripes over Einstein and Galileo CD47-Bot Extra Discussion 6 01-05-2004 00:54
