Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Unread 25-10-2008, 22:53
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
NuVinci CVT Developers Kit
Fallbrook Technologies has announced that a NuVinci CVT Developers Kit will be available for $595 starting in December specifically designed to assist hobbiest in development of Light Electric Vehicles (LEVs).
Press Release: http://www.fallbrooktech.com/05_Pres...s_Intermot.asp
I'm sure hoping we see these in the KoP next year!
Unread 25-10-2008, 23:16
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: NuVinci CVT Developers Kit
hah wowo i was just talking about a cvt transmission at tnt!
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 26-10-2008, 21:58
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
While CVTs are often use in industrial equipment with Fixed speed AC motors, you don't often see them in EV aplications because an Electric vehicle motor has the properties that a CVT typically has. Usually with a 2-3 speed transmission you can get all the performance and efficiency you want/need. Also, CVTs are are typically a double edged sword on the whole efficiency thing. Almost all use a cone, ball, or belt and sheave system that invariably has a little bit of conflicting friction at the contact patch. This friction tend to make CVTs have a lower prowerr transmission efficiency. Where they do a lot of good though is with motors that have a very narrow band efficiancy range (think A/C motors, or some genertator or governed engines). On these applications the CVT can vary output speed while the motor stays in it most efficient or powerful state.
I am a huge fan of CVTs and even designed a new one while in college. If you want a great CVT design resource check out:
"Traction Drives: Selection and Application [Hardcover]
By Frederick W., III and Shube, Eugene E. Heilich"
This is a great book that devotes 50% to fixed ratio traction drives (think gear systems without teeth), and 50% to all metal CVTs (sorry no rubber belt system).
Unread 26-10-2008, 22:16
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
I can vouch for that book, very informative, I was curious how they worked and the book did a wonderful job explaining the concepts to me, a very non technical person.
Unread 27-10-2008, 10:55
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
I was a little bummed that they didn't cover the rubber belt systems used in Snow Mobiles and lots of different machinery, but otherwise though it was a great book.
Unread 27-10-2008, 10:59
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
I got to see this at the makers faire and while it is a cool technology it is very inefficient. They wouldn't tell me the exact amounts but hinted it was not good. Also the ratio range was 3:1 so it would be just a little more then an andymark from top to bottom. I think it would be cool to play with one of these but putting it on a robot doesn't make any sense.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
openFIRST looking for developers Astronouth7303 Website Design/Showcase 1 23-06-2007 22:48
New Developers Needed Astronouth7303 FIRST-related Organizations 0 03-02-2007 19:53
CVT gfreeman9mm Kit & Additional Hardware 6 09-01-2007 20:30
Cvt Jack Technical Discussion 4 05-10-2002 20:59
CVT Clark Gilbert Chit-Chat 10 11-05-2002 19:38
