It all started with FIRST....
Wed. night our animation team went to watch BuddyB309's animations at Artimation for the The Illinois Institute of Art. He had 5 entries selected to be shown. He won more than one award!! He had an amazing lunch with the judges. It was impressive to see the animations on the big screen and even more impressive to realize that FIRST was what helped start him on this path.
Congrats! |
Re: It all started with FIRST....
Yeah, you guys always do an awesome job on the animations! I especially liked this years. Those fridges have to do something. And the Credits really are awesome. That must've taken a long time.
Do you have links to the videos?
I would like to see them. Thanks. |
You can search some of his animations at You Tube at: http://www.youtube.com/user/Buddyb309
He had a couple of the oggy shorts and the Appliance Night Out. I don't think the Appliance one is all on You Tube, but there are portions of it. |
Hey ya'll. I'll give you an update on appliance night out.
Its not on Youtube yet because I'm making the opening and closing credits. There are a few names I still have to contact to make sure I get them spelled right. I don't know when It will be up. Because now I have to make a professional demo reel within a weeks time. Disney wants a copy so they can send out to multiple studios. ugh... I don't believe I'm going to sleep. |
I just have one question: How did you make that completely white background look so good? I can't get the shadows to work the way I want them. And I also wanted to know if you used the Vray renderer. I wish we could get that.
I assume your talking about "The Most Extravagant Credits Ever." I don't use V-ray, I believe its highly overrated. Its actually very simple. Create a skylight, turn on mental ray, then turn on final gather. Set the environment background to 242,242,255 to match the color of the sky light. Create a white plane as the ground. Then create a dancing ted boardmen.
Tutorials!!!! Don't be afraid to rip out your textures on your model to fit your layer that you are currently rendering out. Learn Backburner and set up backburner on your computer to run as a master and a slave. That way it can go through all the layers as you sleep. render out in .tga or .png files so you have an alpha channel. |
#10
Ok, thank you. I knew you were leaving out some key information.
Ive never used combustion, but we do have it. Our lead animator last year was trying to use it, but all that did for him was give him a huge headache. Maybe we'll try harder with it this year. And we only use backburner when we are rendering final whole scenes. Il try to use it more often. And i don't think we ever rendered in .tga or .png files. But it sorta makes sense. Thanks for the info. You really do know what you're taking about. I'l see what we can do with this new found info this year. ![]() |
#11
well to explain what Phil can not...
Chris, our lead animator last year, did attempt to use combustion with .png files along with alpha channels to layer render our animation last year. The trouble we ran into last year is we would have had to render everything 4 times for each frame, alpha of front/back and color of front/back (were front and back refer to different layers and distance from camera), if I remember correctly. This also was the first time that we used combustion so we were not sure what we were doing. Seeing as this process was taking so long we looked into why our animation could not render as each full frame with all layers turned on. In the end when a former team member came back to help us, we used a raytrace material that was overloading all the computers, so we replaced the material with another and rendering was smooth again. and did not take 2 hours on 1 frame. Why it was over loading them I do not know. |
#12
Trying to Help |
#13
I had lunch with him again. He says hes going to track me so he knows when I will graduate.
#14
Well good luck with school! I hope you're having the opportunities for you need.
Trying to Help |
| Help Getting Started with VEX programming. | Joe Johnson | VEX | 5 | 16-04-2007 09:01 |
| Problem getting started with USB 6009 | JimGRobot | LabView and Data Acquisition | 1 | 18-12-2006 09:15 |
| [FF]: Started a Fantasy FIRST myspace group | Koko Ed | Fantasy FIRST | 0 | 04-07-2006 09:23 |
| Getting Started with Scripting | LBK Rules | Programming | 2 | 15-01-2005 01:28 |
| How it all started | Joe Canavan | General Forum | 1 | 04-08-2001 15:44 |
