Go to Post So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed.... - dqmot17 [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 03-11-2008, 20:41
mom1155's Avatar
mom1155 mom1155 is offline
NYC Regional Planning Committee
AKA: Cherrie Fleisher-Strauss
mom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to all
Machines for an Ideal Robotics Workshop?
If there is already a post or FIRST white paper on this subject, please send me the link.
What machines/equipment would teams recommend for an ideal robotics workshop?
Unread 03-11-2008, 21:45
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Re: Machines for an Ideal Robotics Workshop?
Uhm, idk if there's another post, but I have a couple suggestions.
1. Saw, you need a power saw that you can cut through metal.
2. Drill, use a stationary table drill to drill holes into your metal and other things.
3. Sander, many robot parts need to be sanded down and it's just easier to have a power sander around.
Uh, that's really it for POWER tools. We have hand taps and vice grips for hack saws also, but that's not power.
1648: 2013-2014
5283: 2015
Unread 03-11-2008, 21:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
You might check out these threads:
http://www.chiefdelphi.com/forums/sh...ad.php?t=49155
http://www.chiefdelphi.com/forums/sh...ad.php?t=43379
I recall there being at least one more. Can't find it at the moment.
Unread 04-11-2008, 00:03
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
http://www.chiefdelphi.com/forums/sh...438#post658438
(Yes, it's a joke.)
What kind of budget/space do you have for tools? You have the large machines (mills and lathes and similar items) that are easily a few thousand dollars (with the tools that allow them to cut metal) and take up a lot of space, the medium machines (drill presses, sanders, grinders, bandsaws) that are slightly cheaper and take up less space, or even fit on a table, and the hand machines (power drills, jigsaws, chopsaws, and hand tools) that you can pick up for a couple hundred or less at your local hardware store.
There are a lot of options out there; you have to know what you can afford and store.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 04-11-2008, 00:44
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
What is your budget? I'm not sure if you have $1k or $500k.
The answers will vary substantially based on that.
Unread 04-11-2008, 10:51
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
If you have the money a lathe, milling machine, and a welder are nice things to have. Stay away from cheap clones when buying these.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 05-11-2008, 21:52
mom1155's Avatar
What would you put in an ideal dream robotics workshop, if money was not a constraint and you could dream BIG?
Unread 05-11-2008, 22:20
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Dave Lavery, Red Whittaker, Colin Angle, Andy Baker, Paul Copioli, JVN, Karthik, and Kevin Watson
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 05-11-2008, 22:27
Lowfategg's Avatar
AKA: Tyler Moser
Can you give me the Mcmaster-carr catalog number for those?
Unread 05-11-2008, 22:29
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
CNC mill and CNC lathe, with people who know how to use them.
Good drill press, for smaller jobs.
Some form of grinder, maybe 1 surface grinder and 1 pedestal/bench grinder.
Welder that can weld aluminum.
Rich's list of people, and Rich.
Robot storage. Awards case.
Material rack.
Toolbox that stays organized.
A practice field. Preferably as close as possible to the FIRST official ones.
That's probably about $50,000 worth of parts and materials (people costs not included).
Past teams:
Unread 05-11-2008, 22:38
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Actually, with regards to the Toolbox that stays organized, we've found that freshmen works fairly well, and you get to combine cheap labor with the excuse "but we're letting the freshmen help!"
In all seriousness, removable (we use magnetic) labels work quite well.
To add to the list, just three things:
- A computer (laptop?) with programing compiler and Internet.
- Multimeter
- Accurate scale for robot (among other things) at least to 150 lb. or so
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 06-11-2008, 02:30
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Originally Posted by Blue_Mist View Post
Multimeter
Just a Multimeter? I'd go for a nice digital Scope as well. When you start doing much beyond basic circuits, they are amazingly useful.
Unread 06-11-2008, 03:30
Team Role: Teacher
An engineering college student who was in FIRST in high school.
I think good work tables/areas and good lighting is important in a shop. Also, good clamps and vises.
A waterjet can also be quite handy, but very costly.
Unread 06-11-2008, 03:32
AdamHeard's Avatar
Lead Mentor
Originally Posted by sanddrag View Post
A tenacious engineering college student who was in FIRST in high school.
Dave, you left out a word.
  #15   Spotlight this post!
Unread 06-11-2008, 23:37
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
mill, lathe, bandsaw, drill press, arbor press
I agree, waterjets are quite handy.
-Vivek
"we don't build robots, we build people"
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 03-11-2006 11:55
Trinity Robotics Programming Workshop - SOLD OUT! Jessica Boucher General Forum 5 19-09-2006 09:56
SCRRF Robotics Workshop Redhead Jokes Southern California Regional Robotics Forum 1 09-11-2003 13:14
11/23/02 Robotics Workshop Redhead Jokes Southern California Regional Robotics Forum 11 26-11-2002 09:35
