Go to Post Continuous improvement isn't rocket science. - JVN [more]
  #16   Spotlight this post!
Unread 06-11-2008, 12:47
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Prototype Drive
Originally Posted by Andrew Schreiber View Post
Someone correct me if Im wrong but I was under the impression you can only water jet plate. The issue being, the water tends to spread as it goes through the material.
Now laser cutting might work...
Generally some sort of material is put inside the extrusion so that it only cuts through one wall; 233 has done this, and I believe they use a 4x4 piece of wood inside of 4x4 extrusion when they waterjet that. I'm not sure if it would work with wood when applied to a piece with only 1" thickness, but I'm sure there is something that would.
  #17   Spotlight this post!
Unread 06-11-2008, 18:31
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Re: Prototype Drive
Originally Posted by AdamHeard View Post
... and cantilevered wheels are features that have been done before by teams, so assuming you've done the math...
I doubt that most have done the math. And a cantilevered wheel on a 1" x 2" aluminum frame member that has been skeletonized makes me leery of the durability. Obviously it depends on the amount of stick-out, but I was surprised at the twisting forces we encountered when using full 2" x 4" x 1/8" box aluminum. Your results may vary.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
Team 1583's 6 wheel modular drive prototype NOV8R Robot Showcase 8 08-01-2008 11:57
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Team 610 Off-Season Tank Drive Prototype Jonathan Norris Extra Discussion 14 06-11-2006 01:59
