Go to Post Crazy is relative - dtengineering [more]
Unread 08-11-2008, 18:34
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Ball Differential parts
Unread 08-11-2008, 18:35
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: pic: Ball Differential parts
Clever... I never would have thought of that as a differential mechanism.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 08-11-2008, 19:20
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
This is an "Old School" design that has worked beautifully for years in the RC Car world. Although, with RC 's, the motors output pinion would engage teeth on the outside of the ball ring. Then the left and right drive wheel would be attached to the outer plates through more gears. Compression force would be used against the outer plates to regulate the amount of slippage that occurred between the two output shafts.
(For those of you who are/were RC junkies, think RC-10)
This is a great adaptation of that design. Well done!!
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 08-11-2008, 21:23
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
My Rc car's got 2 of these but way way tinier with carbide diff balls.....
associated rc18t (cute little guy) with a mamba 8000kv brushless setup and a 3 cell lipo.. the ball diff slips a bit sometimes lol.
These have largely been used in the RC car world because its alot easier to make them tiny as opposed to the bevel gear type, the larger cars and trucks do use gear differentials though.
i kinda wanna drive this base you got going...
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 08-11-2008, 21:54
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
I've got the original RC-10.
I've replaced almost every part over the years, especially the bearings.
Which brings me to my point, that you should replace those cheap sheet-metal OSH bearings with something better. Those things will deform quickly (especially if you apply enough pressure to the races) and not turn as well.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 09-11-2008, 10:34
joeweber's Avatar
Coach team 1322
Team Role: Coach
Rookie Year: 2000
The whole system is a test stand for development. With funding low preseason we are trying to build everything low cost just to see how it works. When we build the actual ball differential we will use harder bearings. Once we figured out how to put it together and did assemble it we found that it was easy to assemble. The most difficult was the ball guides that are welded to the shaft. We drilled the center hole in the steel and than drilled the holes around the center (they do not have to be perfect off center to work). We than welded the plate to the shaft and than lathed it out to make it round. We than threaded the rod. The rest we just had to slide spacers and bearings into place. We drumeled the keyway for the wheels.
To test how tight they have to be we will prop up the mecanums up with casters and than run with just the omni wheels. This should give us a good idea on the amount of slippage under pressure.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
pic: FTC Team 381 Rosie's Lil Sis Dual Differential Drive psyco_klown Extra Discussion 2 28-02-2008 08:30
pic: Team 34 - Differential Ed Sparks Robot Showcase 13 25-02-2008 10:15
pic: Differential Swerve (Close Up View) with Advanced Gear Kit nonother Extra Discussion 8 16-05-2007 01:14
pic: Differential Swerve (Bottom View) with Advanced Gear Kit nonother Extra Discussion 0 14-05-2007 23:31
13" ball and other parts Mr. Mac OCCRA 0 15-10-2003 22:49
