Go to Post Dave Lavery just responded to one of my posts. I think that I might die. - Karibou [more]
Unread 11-11-2008, 11:07
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
State Based Machines in LabView
A common design pattern to use in robotics is a State Based Machine. A State Based Machine lets you have different 'states' of behavior that your robot might exhibit, and governs rules for transitioning from state to state. For instance, your robot might be in a state called "Search for Game Piece" and use its camera to try to find a vision target. Once it finds it, it could transition to a state called "Drive to Game Piece", then once it arrived at the game piece it could transition to "Pick Up Game Piece". For more depth about State Machines, check out this Wikipedia article: http://en.wikipedia.org/wiki/Finite_state_machine
I've assembled a series of videos explaining how to build a Soda Machine in LabView as a State Based Machine. A soda machine is a good example, because it goes through many states as the user buys a soda:
  • "Add Money"
  • "Choose Item"
  • "Deliver Item"
  • "Return Money"
Each video is about five minutes long, and by the end you'll be 90% of the way to havin a working LabView soda machine! The tutorial videos assume you've used LabView before, but all advanced concepts are introduced as I do them.
You can find the videos online here:
http://vimeo.com/album/26321
I hope this helps! Please let me know if you do the tutorials and what could be improved or worked well!
State machine in LabVIEW? JBotAlan National Instruments LabVIEW and Data Acquisition 3 23-10-2008 07:59
Opinions wanted: LabView-based controller? Dave Flowerday Control System 41 23-06-2008 10:05
Hawaii Gov. Lingle State of State speech-FIRST and STEM MoeMom FIRST In the News... 0 29-01-2008 17:04
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 03-11-2006 11:55
State Machines doyler Programming 7 11-01-2005 00:53
