Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 12-11-2008, 15:16
bernieseaholm bernieseaholm is offline
FRC #2960 (automation nation)
Team Role: Teacher
bernieseaholm is an unknown quantity at this point
[OCCRA]: spike relay polarity question
it seems that regarless of how the spike relay is connected, we are only able to have it switch to "red", the trigger functions does not switch to "green" when depressed. we do not have it hooked up to a motor to reverse direction, only a solenoid valve. we have tried different pwm cables, different spikes, same result.
any ideas as to why this is occurring and will it matter if only switching the solenoid?
thanks
bsimms
Spike relay question Zack Briggs Electrical 17 19-02-2008 14:48
Spike Relay Wire Gauge sparrowkc Electrical 7 12-02-2008 14:26
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
