Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 17-11-2008, 14:44
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Re: Timing Belts for 6W Drive
The statement that belts cannot handle high torque is false. Lots of machines like large mills and motorcycles use belts without any trouble.
The problem with belts is that they are not good at changing directions quickly. Often, when they go from forwards to reverse very quickly, (as in a FIRST robot) they skip teeth or go flying off.
Notice how 118 only needs to drive their wheels 1 direction?
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 20-11-2008, 22:20
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Sounds like with timing belts it's harder to order the right thing and set-up, but may be more durable and not need tensioning.
Originally Posted by Teched3 View Post
I would also suggest using a COTS belt rather than try to put a custom length onto your machine.
We have also used the drive configuration you are considering, but would suggest runnng the wheel to wheel belt from the mid wheel to the front, rather than the rear.
What is a COTS belt? Great suggestion with having transmissions in back, will do.
Unread 20-11-2008, 22:29
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
COTS stands for Commercial-Off-The-Shelf. The alternative would be a custom length belt.
Unread 20-11-2008, 23:38
Big Ideas Big Ideas is offline
Mentor
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Rookie Year: 2007
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
Properly installed chain is definitely more efficient then timing belt (or any other drive system). That's why bicycles have gone back to chain time and again. Should be less expensive also. You don't have to order the right length. You don't have to compromise your design to fit an available belt length. Splicing a continuous loop belt is not easy to do well and lowers the strength, torque rating, and durability. You can break chain to remove/install with other drive elements still in place. Timing belts have advantages for noise, accuracy, longevity, low maintenance, set and forget, as well as a back surface that can transport objects.
V belt is less efficient than timing belts.
Steve des Jardins
Mentor Team #2102
Unread 20-11-2008, 23:49
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
I bet you would be surprised by how many different lengths timing belts come in. They come in very small increments (on average about .05" increments) from 2.8" up to 220", so you really aren't "compromising" to fit an available belt length.
https://sdp-si.com/eStore/Direct.asp?GroupID=213
I would definitely not recommend trying to splice your own belt for the reason you stated involving lower strength, torque rating and durability.
I've said it before, and I'll say it again, I think if teams are interested in belts there really isn't a great reason not to give them a shot. There are pros and cons to each setup (chain vs belts), its really up to the team and how far outside their comfort zone they want to step.
edit: apparently i've hit 1000 posts after ~5 years of browsing CD
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 21-11-2008, 01:00
CraigHickman
Posts: n/a
Out of curiosity, could some team that has used timing belts with great success post up the type of belt they used (part numbers and so on), possibly with the addition of a picture, so we can all get a clear idea of what's been proven to work?
Also, How much weight is actually saved between a #25 chain vs an equivalent strength belt? And is the cost any different?
Timing belts kajeevan General Forum 6 13-08-2008 13:59
Join timing belts GMAdan Technical Discussion 5 19-04-2007 16:03
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
