Go to Post 50 years from now, the FRC will still be waiting and hoping for a water game. That's my prediction. - TheBoulderite [more]
Unread 20-11-2008, 16:53
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: off center 6WD help
Originally Posted by Gaurav27 View Post
Eric mentioned omni wheels. Just thinking aloud here...
Should omni wheels be on the end where CG is greater or less than the other end? The end that has a greater CG would remain on the ground for most of time where as the end with less CG. So the end with omni wheels will help in turning and thus should be on the end with a larger CG.
When using omniwheels, you'd typically eliminate the "rock" from your 6WD -- and so both ends are on the ground at all times.
Assuming that you have four traction wheels and two omniwheels, you'll want for your center of gravity to live above the traction wheels, not the omniwheels. Increasing the total percentage of the robot's weight acting through the traction wheels increases your tractive force compared to placing it over typical omniwheels because the omniwheels have a lower coefficient of friction.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
help with 6wd chassie.. Magic General Forum 7 29-03-2008 14:27
Toggle Motor On & Off Help..... programmr Programming 1 16-02-2008 11:15
Off-season help Setsanto 3D Animation and Competition 12 24-02-2007 17:26
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Off Center Bearings Rickertsen2 Kit & Additional Hardware 2 09-01-2003 22:58
