asynchronous???
http://decibel.ni.com/content/community/first
reading the folder displayed at 3:56 min of the video.. I think one of the folders reads "asynchronous start" , "asynchronous stop" as well i see the standard "autonomous" as well as "tele operated" any thoughts why we might need an asynchronous program?? apparently (from what I hear) the new controller can communicate with other robots.. thoughts.. speculation?? Mr Yeagle TEAM 2229 |
Re: asynchronous???
I suspect that these were test files to make sure everything was running smoothly, but i could be wrong.
Re: asynchronous???
Tasks that do not need to be synchronous to each other can now easily be split up and handled separately. For example, the compressor runs asynchronous to the joystick/drive base. If you have a vision based turret, this can now run completely separate from the drive base. Perhaps those are the VIs that help launch separate tasks? Not sure, just speculatin`. |
Re: asynchronous???
Doesn't asynchronous start/stop just mean that response to the command is immediate and cannot be delayed by other operations?
Seems like that would be an absolute requirement for an emergency stop feature. |
Re: asynchronous???
These elements will start and stop a task that then runs asynchronously or independently from the rest of the program. There are definitely uses for this, but I will wait till the code comes out to reveal the rest.
Greg McKaskle |
