Re: Shifting Two Anymarks with One Pistion
to save more weight and air you could use servos to shift
also i was thinking about somehow shifting two with on small motor if we get a small enough one in the kit? |
Anyone wanna weigh in on servos? |
we used them on our 2007 robot and they worked good(not as well as the pnuematic shifting though)enough to allow the robot to do wheelies, using servos would be less complex,I've never had a servo break before, and you could probobly replace that piston with a single, small, motor(like the fischer price maybe) and shift both(dont know if this would work any better but the idea is out there now) |
it saves more air for use because i think we used 1 inch pistons to shift in the past not 1/2
| Shifting with easyC | Erics626 | Programming | 1 | 24-01-2006 18:58 |
| One or Two Wheel Shooter | Nitroxextreme | Technical Discussion | 6 | 14-01-2006 01:10 |
| [ECDU]:one or two | Michael Leicht | FIRST-related Organizations | 16 | 09-12-2004 07:23 |
| one control stick or two? | 346operator | Technical Discussion | 24 | 12-08-2004 09:59 |
| Control system with one joystick(or two) | CharlieWilken | Technical Discussion | 3 | 04-02-2002 09:20 |
