Re: pic: Mecanum Musings
Woah, the assembly for these looks incredibly easy!
Great design. |
that mecanum looks really good, reminds me alot of the WPI wheel from 2005 except a little smaller. Do you have a view directly from the side so we can see the complete arc of the rollers?
You're completely right. My apologies for getting off topic.
How wide do you think the wheel would have to be to give a smooth ride? |
Here's a render of the latest revision. It's little bigger (effective diameter of 8ish inches), and uses more machining resources. to shave weight off. Once I hit a revision that i feel comfortable putting on a robot, I'll be hosting the CAD for anyone that wants it, with only one rule: if you make it or modify it, you also have to put the CAD up. It's time to bring Open Source to robotics, folks. ![]() |
Great design. Do the nuts and bolt ends miss the carpet? You may want to look into tapping one end of the c-section and countersinking the clearance on the other. Then you could use a flat head screw and match the length of the screw to the c-section width. Then you should be able to avoid any hardware overhang and further reduce the weight. Typically you should have at least three full threads for any bolted joint.
Keep up the great work and please post your final version! |
I'd love to post the final version, but for me all designs are a work-in-progress. Maybe I'll post some renders side by side with a real thing if these actually get built? It's all really up to the team for what they'd like to build. I am just a mentor, anyway. |
Just a mentor? You say that like it's unimportant...
I understand the importance of the position, but I see the limits in the spot. I'm here to teach students about engineering and smart decision making, not win them a competition. If that were my job, you'd be seeing a lot more designs up here that I "planned" on making, and justification on why they're the best.
Instead, I spend my time designing and planning parts and mechanisms with the intent of showing students that there are more possibilities than the most complex (high school students seem to be good at finding the most difficult solution first...) and expensive option. A mentor should teach the team, not BE the team in my opinion. |
| pic: vex mecanum 1 | psyco_klown | Extra Discussion | 9 | 05-05-2008 23:22 |
| Musings from a FIRST Inspector | Wayne Doenges | General Forum | 36 | 26-02-2008 21:31 |
| pic: Mecanum Prototype 1 | Doug G | Extra Discussion | 8 | 06-04-2007 21:34 |
| pic: 1" mecanum | Tytus Gerrish | Extra Discussion | 8 | 04-10-2005 13:44 |
| Sweet Repeat musings........................ | skrussel | Off-Season Events | 3 | 19-10-2003 23:33 |
