Go to Post I check Chief Delphi more often than I check Facebook and Twitter combined. It's probably unhealthy actually... - Ginger Power [more]
Unread 21-11-2008, 18:54
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
What is your team doing with their controller?
I would think that most teams with the funds to do so would request the early controlls system shipment.
Now I want to know what you guys are going to do with yours!
Are you going to put it in an old bot,
Put it in a new bot,
Only Benchtop test it,
or put it in a catapult? (I hope not)
Unread 21-11-2008, 21:01
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Re: What is your team doing with their controller?
Building a new drive base to test code, practice driving, and experiment with (we have omnis now! and traction wheels).
I cut myself shaving with Occam's razor.
Unread 21-11-2008, 21:18
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
We are going to stick it on a Vex robot first to use it as a small test robot as we build our first test base before kickoff (which we will switch the controller over to).
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 21-11-2008, 21:32
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
How do you plan on fitting all that on a vex robot?
Team Leader
Team 1595
Unread 21-11-2008, 21:34
Lowfategg's Avatar
AKA: Tyler Moser
Guess you will have to wait for a picture! Lets just say we know how to smash things into an 18" cube.
Hmmmm.... Should we put it on Max 3 or 4.
Unread 22-11-2008, 03:17
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
We're going to start off with benchtop and try and get use to the development process as quick as possible. After that our build guys have been working to make it fit onto our bot from RacknRoll. Then the goal is to reprogram that bot with the cRIO. LabVIEW to be exact, since that is what our team has determined we're going to use.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 23-11-2008, 00:09
AKA: Samir Shaikh
FRC #4329
that would be an expensive cube!...i do want to see the pics though
What is your team doing for your presentation. Lil' Lavery Chairman's Award 14 29-02-2004 12:16
What is your team doing on April 29th? archiver 1999 0 23-06-2002 22:35
What is the best thing your team is doing for promotions? prtynpink5 General Forum 14 08-04-2002 14:28
What is your team doing??? ben_whly Chairman's Award 0 20-01-2002 12:23
So What is your team doing from now till Kickoff Todd Derbyshire Rumor Mill 25 04-12-2001 23:13
